Building a 2.3 stroker balance shaft or no balance shaft ?????
Old Feb 23, 2007 | 05:47 PM
sterdyevo's Avatar
Old Feb 23, 2007 | 05:52 PM
smokedmustang's Avatar
I have NO balance shaft. So I say NO.
Old Feb 23, 2007 | 05:53 PM
DRFTKNGG's Avatar
Balance shafts if you only plan to rev to 8K.
No shafts if you wanna rev 9K and up.
Old Feb 23, 2007 | 06:11 PM
Paul Nelson's Avatar
I talked to Jackson Machine and they said on all there strokers they run the balance shafts and the 2.0 they run them without
Old Feb 23, 2007 | 06:13 PM
8URVTEC's Avatar
I don't have a balance shaft, so I second the "no"!
Old Feb 23, 2007 | 06:59 PM
94AWDcoupe's Avatar
I like them in. I like smooth factory like performance.
Old Dec 8, 2007 | 02:13 AM
Johnboy1065's Avatar
with some kits like mine I couldnt leave them in because a rod made contact with a balance shaft. BUT I'm not running the normal crank that comes in the AMS kit. I upgraded to the Eagle crank that they offer. this is probably why it makes contact.
Old Dec 8, 2007 | 05:47 AM
20Grockit's Avatar
i say no to the balance shafts. you can rev higher w/o them
Old Dec 8, 2007 | 09:44 AM
Kc2Buk's Avatar
With what turbo?
If you plan on running a stock 16G or a 20G 9 LT (Green) keep the BS "balance shaft".
If you plan on running a Big Turbo, lose the BS, and be all you can be 9-10K rpm.
Old Dec 8, 2007 | 10:39 AM
DS-03evo's Avatar
Originally Posted by Kc2Buk
With what turbo?
Why would you want to rev a 2.3 to 9-10K?
Keep the shaft, it will make it smoother.
Old Dec 8, 2007 | 11:11 AM
PVD04's Avatar
+1
I have a 2.3 without balance shafts and I would recommend keeping them in.
-Paul
Old Dec 8, 2007 | 11:36 AM
Smogrunner's Avatar
You can feel the added vibration without the shafts, but you make more power without them. I've run my 2.3 without balance shafts for 23,000 miles, two road race events, two drag race events, and over 100 dyno pulls. If I had to do it all over again, it would be a coin flip - I do miss the smoothness though.
Old Dec 8, 2007 | 12:08 PM
dafunk630's Avatar
no balance shaft FTW!!!
My03evo
17
Jan 6, 2017 10:36 AM
tkrizzy3
Oct 6, 2015 06:27 AM
nacsa
Oct 3, 2015 03:26 AM
Jackson Machine
18
Sep 14, 2006 09:57 AM
ace_2822
Automotosports - Illinois
Feb 10, 2006 07:11 PM
