Balance Shaft Installation
Old Feb 7, 2018 | 07:51 PM
fireroasted's Avatar
hahaha, no I dont know how to measure oil clearance actually.
I did apply assembly grease, so I expected them to be somewhat stiffer. However, now I worry that the bearings are too 'tight'. So I guess measuring oil clearance is something I need to learn.
As I am installing the front case I realized that the front balance shaft doesn't 'fall' to identify which turn is the appropriate timing mark. I can turn it, but it certainly doesn't free fall.
Now I need to figure out if that is just because there is only assembly grease instead of oil, or if that is something that requires the bearings removed and reinstalled.
What would you expect with assembly grease only on the bearings?
Old Feb 9, 2018 | 07:25 AM
ladiesman285's Avatar
5 Year Member
Balance shaft oil clearance
The balance shaft oil clearance is actually very tight. Much tighter than the connecting rod oil clearances. The thickness (viscosity) of the assembly lube you used may hinder the balance shafts spinning freely but if you were to use regular engine oil on the shafts the balance shaft counterweights should still be able to rotate the shafts via gravity alone. I would take out the balance shafts and visually inspect both the bearing and shaft oil surfaces to make sure there is no scoring or signs of mechanical interference between the shaft and the bearing surfaces. Then reinstall them with a coat of engine oil on the bearing surfaces and check to see if they spin freely from the force of gravity on the counterbalance weights. Here is a youtube video of a mechanic spinning the balance shaft to find the proper counterbalance location:
In the video you get an idea of how the balance shaft spins freely by hand.
You don't want to install them if there is metal on metal contact due to the bearing lip being deformed from being pressed in, this will most likely cause premature balance shaft failure and cause your engine oil to get metal debris in the supply.
Old Feb 9, 2018 | 08:15 AM
alpinaturbo's Avatar
Stock dampener is used in most big builds, stroker no stroker.
Completely misguided statement that you have to replace it: read discussions rather then taking one mans input for fact.
Benefit of aftermarket dampeners was never quantified, ie measured and verified.
It’s speculation- some of it plausible - but nobody denies stock to be great.
Old Feb 9, 2018 | 08:49 AM
"You don't want to install them if there is metal on metal contact due to the bearing lip being deformed from being pressed in"
So I checked that there was no friction or edges. Actually I did have the one of the bearings deform slightly causing the shaft to only go in part way easily. I took that bearing out again, and put in a brand new OEM bearing. So theoretically I checked carefully but even when in neight shaft spins freely. As if the bearings were 1/2 thousands smaller than the ones that came out years ago.
The rear shaft was easy to confirm that it was not spinning freely. Should that shaft also fall with gravity as easily as the oil pump or front shaft as shown in the video?
Right now I am only identifying the oil pump side shaft as too stiff.
Is there anything understood between OEM vs the ACL bearings? tolerances, etc?
Old Feb 9, 2018 | 12:24 PM
5 Year Member
I was able to use ACL bearings with no issues. Both shafts should be able to rotate freely just like in the video.
Old Feb 14, 2018 | 12:06 AM
I have taken both shafts out again and inspecting the shafts themselves seems like they may have some rough surfaces at the edge of the bearing races. I probably need a machine shop to polish them. Is it possible to do that myself, or DIY somehow?
I can't tell if the bearing themselves that are in the block are damaged in any way, but they went in easy enough. The OEM bearing however has a noticeable lip in the inside where the seem is. But the ACL bearing does not have that 'bump'.
however it feels like maybe the bearing gets smaller as its inserted. They certainly don't just fall to rest via gravity. They both require force to turn.
Old Feb 14, 2018 | 07:40 AM
Project_Broke's Avatar
My OEM never replaced shaft bearings don't "fall" without a little force.
I would say it's normal.
Old Feb 15, 2018 | 09:06 AM
Chrispy0530's Avatar
Originally Posted by Abacus
Stock bottom end can use balance shafts since its a factory designed engine if its not going to be spun over 8000ish regularly. Mitsubishi engineers designed everything to work together .
Whenever you go with aftermarket pistons and rods, or a crank that will change the harmonics of the engine and the shafts will need to go. You would also need a good dampner with that route as well. Going to a stroker engine will increase harmonics and good balancing/ dampner are a must.
So if I am understanding this correctly as I am going through a rebuild process myself. The balance shaft is recommended to be removed if going with forged internals ( Eagle H-rods / Wiseco HD Pistons )? Why is this? I was going to keep the balance shaft.
I apologize if I understood this incorrectly lol.
Old Feb 16, 2018 | 12:38 PM
drive955i's Avatar
Although I understand the sentiment, and I personally agree with the notion of removing the shafts when upgrading internals (my opinion), the balance shafts are installed to quell second order harmonics, not the rotating assembly itself. When two pistons move downward, one is on the intake stroke while the other is on the power stroke, likewise, the opposing pistons are on compression and exhaust strokes. All the pistons are under the influence of various loads, causing the crank to get “shoved” and “twisted” in various directions, causing vibration. The balance shafts oppose these forces, decreasing engine vibration. Doesn’t really have anything to do with the reciprocating weight. The vibration damper on the other hand cancels third order harmonics, and is directly related to reciprocating weight and engine speed. Whew!
boostawd16
Nov 20, 2013 04:47 AM
STIKiller4G63
10
Oct 2, 2012 07:44 AM
Anarchy99
11
Mar 7, 2012 12:17 PM
okevolutionVIII
33
Oct 30, 2011 08:05 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
