Question regarding ECU & BC...
Old Apr 7, 2004 | 10:53 AM
BLiu's Avatar
I have a question for those with the ECU. I know that Works, Dynoflash, and Vishnu claim that the ECU holds the boost better than the stock ECU...
My question is: if I get a reflashed ECU, is it really necessary now to get a boost controller or does the ECU do a pretty good job at holding boost? Eventually I would like to go higher boost, but for now, I am wondering if a Boost controller is that necessary. Thanks for any help.
Brent
Old Apr 7, 2004 | 11:33 AM
prowler's Avatar
This has been discussed quite a bit.
Dynoflash helps hold boost a bit more, but it will still taper.
Works/XEDE raise boost by removing the pill.
