Front case breather mod ( at rear balance sprocket )
When doing balance delete can you turn the defunct sprocket position in to a breather outlet for crank case ventilation?
Any threads or pics? I'm thinking of installing AN threaded nipple there
Hmmmmm the stm vent is out the side of the block and only looks -6 max? If you went at the case I'm sure you could get -10 but I'm not sure if a fitting and pipe work would clash with water pump pulley or anything else in that area maybe even aux belt?
It is possible, but every setup is going to be different. At a minimum run the line uphill as long as possible so as much oil can drain back in the block before getting to the can. For a typical streetcar there are better ways to vent the block so you dont fill up a catch can just cruising around.
https://stmtuned.com/collections/mit...eather-fitting
Willpegley
21
May 14, 2018 04:00 PM
