Clutch Slave/Clutch Fork
Old Feb 27, 2018 | 07:04 AM
blackline's Avatar
5 Year Member
So installed a new clutch, TOB and bolted the transmission up but I notice the clutch fork is facing the passenger side. Even when I remove the the slave cylinder it's still facing the passenger side. Did I **** up on installing this TOB and/or fork??
Old Feb 27, 2018 | 07:41 AM
heel2toe's Avatar
Ugh is that lil circle thing where the tip of the slave goes into on the clutch fork facing passenger side? If so its in backwards Guess you'll be dropping the trans again...
Old Feb 27, 2018 | 07:49 AM
blackline's Avatar
5 Year Member
not that, mybad I kinda explained it wrong. Cant get the TOB to snap into the monolock
Old Feb 27, 2018 | 07:55 AM
lonestarr20's Avatar
It is facing the correct way, don't be afraid to use your muscle on this part, pullback on the fork, and it will snap into place.
The fork will rest in The middle of the opening once completed.
Remove the slave cylinder before you start.
Old Feb 27, 2018 | 07:57 AM
maxroach's Avatar
Did you try engaging / disengaging the TOB to Monoloc when still out?
If so,
TOB didn't engage the Monoloc.
Lossen just a bit all the trans bolts that you can wiggle the tranny same time push fork towards driver side.
Old Feb 27, 2018 | 08:07 AM
blackline's Avatar
5 Year Member
Going to try this tonight, thanks
If so,
I'll try this if the above method doesn't work, thanks
Old Feb 27, 2018 | 08:14 AM
six40's Avatar
And as mentioned, don't be afraid to muscle it a little bit to snap it back in place. Don't go ape on it but don't be soft and gentle. A firm swift pull should get it in if all else is good.
Old Feb 27, 2018 | 07:53 PM
blackline's Avatar
5 Year Member
Thanks fellas! I was able to pull the fork far enough to where to "clicked" into the monolock...so damn happy about that.
I did bleed the clutch but the peddle feels very airy until about 1/2 way then it feels good...any clue to why that is?
Old Feb 27, 2018 | 10:28 PM
maxroach's Avatar
Glad that you engaged it.
Follow this first:
adjusting clutch by Jack T.
and re-bleed it.
Old Feb 28, 2018 | 06:02 AM
blackline's Avatar
5 Year Member
Follow this first:
https://youtu.be/vYJxQyjIhUw
and re-bleed it.
Thanks, Hopefully this removes the play of the clutch pedal.
bostonhatcher
Jan 4, 2015 01:22 PM
mchristian
Dec 14, 2013 10:32 PM
car_nut15
14
Apr 18, 2013 11:59 PM
Gleason at STM
Evo 'For Sale' Engine Internals and Drivetrain
68
Mar 4, 2012 10:38 AM
simons3z
Feb 12, 2011 01:06 PM
