Intake Discussion (Warning, this will be really long write-up)
#31
You said iac bypass but the thing I cut off was the egr. The eBay tb has full iac
I didn’t modify the runner dividers. It would be really really hard to do properly without cutting open the plenum.
I saw you got the measurements from the other thread. Are those ‘ported’ ? I would be cautious of following measurements without any other reference. There’s a LOT more to flow stuff than two numbers like that. How did they make it bigger? Raise roof? Drop floor? Little of both?
if you do adjust the size remember to run it up into the port not just a glorified champher
I doubt his is ported. It's too close to the unported IM.
Lancer_Evo_8
Jun 20, 2015 06:39 AM
