Snapped Manifold Stud
Old Apr 6, 2018 | 09:26 AM
ineedboostman's Avatar
If you don't have any experience doing this I wouldn't recommend it but I've done it countless times. If it's relatively flush or even in a little bit you can use a nut about the same size or a little bit smaller. Put the rod thru the nut holding onto it with a vice grip, glove and pull the trigger. If you do it right you 'll get a bite on the stud and the nut will stick. Hopefully heat will help it spin out once you put a wrench on it.
cficare68
23
Feb 19, 2021 11:09 PM
letMeIn
12
Feb 23, 2010 07:43 PM
sekula
Oct 26, 2009 12:32 PM
Gary@MellonRacing
Aug 6, 2009 06:22 AM
93civEJ1
13
Mar 17, 2006 06:03 AM
