snapped exhaust manifold bolt that attaches to head, need help
Hi. Well I was taking exhaust manifold off the other day, and 1 of the bolts that holds exhaust manifold attached to the head, snapped on me. I used liquid wrench since all of them were rusted badly, but previous owner might have over torqued it, because as soon as I started to unscrew it, it snapped on me very easily. Now Im stuck with 1/2" broken bolt attached to head.
Any idea how I can take it off ? I tried to heat it up with one of these small butane torches, and use pliers to make it loose but didn't work.
Did it snap flush with the head?
If you didn't screw the threads up already trying to use pliers, you could try and double nut the stud and back it out with a wrench. Spray some PB blaster on there and let it sit for a while before you try that though and then heat it up with a propane torch and it should come out.
EZ out should be one of the last steps to try, they break all of the time. You get that broken off in there, good luck trying to drill through it.
do the double nut trick. if that doesn't work, then resort to using a set of vice grips. The vice grips will mess up the thread so that's why you want to do that after you try the double nut. Also relaly soak it with blaster like bob said
weld the nut to the stud sticking out and also im pretty sure that it back out by turning to the right.....if i'm wrong please correct me but if i recall correctly that was our problem. and it is a beeotch to drill it out.
thx guys. will keep you posted. I can only work on the car on the weekends. Will try your ideas this saturday. Maybe I should try to take all of them out, and replace with new bolts, but then again I don't want to screw up the good ones.
I cleaned rust on all of them with a metal brush and a drill, but wouldn't mind replacing them for the future.
You would turn it out counter-clockwise (left) to turn a bolt out
+1 on the welding. done this before and it works great, weld won't stick to the aluminum.
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
HiRevnVIII
11
Oct 5, 2005 11:13 AM
