redline or Amsoil for 6 speed MR tranny?
Old Jan 15, 2010 | 12:04 AM
vietdragontekx's Avatar
time to change the fluid, which one you guys recommend? i been using redline MT 90 and MTF mix, and the last one i used 75w90 mobil 1 in tranny.
time to switch to something better.
what about transfer case and rear diff?
thanks guys
Old Jan 15, 2010 | 12:06 AM
MR. EVO MR's Avatar
My tuner said redline
my car is currently in the shop doing her 30k service, I'm using redline fluids.
gl either way you go
Old Jan 15, 2010 | 12:07 AM
kanyonkid's Avatar
neither, i recommend MIL.SPEC's oil... pm them or call them.. the shop guy has like 85k miles and i think over 400whp and tranny is golden still... same with mine
Old Jan 15, 2010 | 12:11 AM
i ran Mil. SPEC Castrol SynTorq 75W-85 full synthetic before and it ran great but it doesn't last very long.
how often do you change your?
Old Jan 15, 2010 | 12:20 AM
Erik@MIL.SPEC's Avatar
It's 115,000 miles
Old Jan 15, 2010 | 12:23 AM
Originally Posted by Erik@MIL.SPEC
It's 115,000 miles
how often do i have to change it Erik? i bought from you several time already but the fluid didn't last very long, i change it every 12k.
i daily drive my car sometime.
Old Jan 15, 2010 | 12:56 AM
yahu's Avatar
What do you mean by "...the fluid didn't last very long...?" It was noticeably notchy and time to change or something else indicated that it had run its course? Did you get anything analyzed to ensure your thoughts were correct?
Old Jan 15, 2010 | 02:23 AM
by no mean that im saying the castrol syntorq sell by milspec is bad. it's one of the best fluid i used for my tranny. So far it's the smoothest to shift with my MR tranny. but after 11-12k the tranny tend to get difficult to shift into gear when it cold. when i first change it, the tranny goes into gear and have no notchiness. I would definitely use it again thought! thinking of buying another 3 qts for my next tranny change. =).
Old Jan 15, 2010 | 07:55 AM
Taimur's Avatar
I just put in Amsoil MTG in my 5 speed. When cold trying to get it into any gear is nearly impossible. I'm going back to stock since I believe it preforms the best.
Old Jan 15, 2010 | 09:13 AM
Kracka's Avatar
I recommend Redline for the 5-speed transmissions, but for the 6-speed the Castrol stuff that Mil.Spec sells is my choice.
Old Jan 15, 2010 | 09:14 AM
Kracka's Avatar
Try Redline next, it worked great for me even in -15F temps during Minnesota winters.
Old Jan 15, 2010 | 09:48 AM
halfnhalf83's Avatar
im running AMSOIL MTG in my 6spd here in WA, and its been the best thing SO FAR. ive tried OEM, REDLINE MT90 (bad mistake), and now AMSOIL. shifting is really smooth, and only slightly notchy on cold mornings for first couple miles in 1st-2-3rd. Other than that its great!
Old Jan 15, 2010 | 09:53 AM
Personally, I am a little neurotic...so I tend to change the Castrol stuff every 10k to 12k. I agree, it seems to perform a little less perfect from 12k to 15k (15k being the recommended OEM change).
However, having to change the fluid to get that "perfect" feeling 3k before the recommended fluid interval is WAY BETTER than dealing with the crap notchy feeling the OEM fill gives you.
Old Jan 15, 2010 | 11:23 AM
psphinx81's Avatar
AMSOIL hands down
Old Jan 15, 2010 | 11:50 AM
Originally Posted by psphinx81
AMSOIL hands down
Have you had experience with AMSOIL in an MR 6 speed transmission?
