redline or Amsoil for 6 speed MR tranny?
Old Jan 15, 2010 | 04:10 PM
vietdragontekx's Avatar
hey erik, how often do i need to change your castrol syntorq if i drive it daily with no beating on it.
Old Jan 15, 2010 | 06:20 PM
apagan01's Avatar
Originally Posted by Erik@MIL.SPEC
Have you had experience with AMSOIL in an MR 6 speed transmission?
Hundreds of customers and they have had great sucess on MR's
Old Jan 15, 2010 | 06:35 PM
halfnhalf83's Avatar
+1 ive been the happiest with the AMSOIL MTG fluid in my MR 6spd trans.
its far better than the OEM diaqeen and the Redline MT90.
apagan01 what would you recommend for the transfer case?? severe gear??
Old Jan 15, 2010 | 07:49 PM
Erik@MIL.SPEC's Avatar
That wasn't a knock on AMSOIL, it was a comment regarding someone saying a particular fluid was a good choice when their signature says they own an '03 Evo with a 5 speed.
That's good that customers have had good experience with AMSOIL in their 6 speed. However, I don't think AMSOIL offers a 75W-85 exact equivalent to the Super DiaQueen.
Old Jan 15, 2010 | 07:50 PM
I think I mentioned previously, I change it out every 10 to 12,000 miles which is before the factory recommended change every 15,000 miles.
Old Jan 15, 2010 | 09:07 PM
bsmart82's Avatar
I have Amsoil MTG in my MR and in less than 30* weather 2nd gear is a b!tch and 3rd is a bit notchy when the trans is cold. I will be going back to Diaqueen in my Evo and Talon here very soon.
Old Jan 16, 2010 | 07:23 AM
apagan01's Avatar
i never took it as a nock on AMSOIL but as you were looking for feed back.
Old Jan 16, 2010 | 07:25 AM
apagan01's Avatar
i reccomend SVG 75W90 wich is what all evom is using,,,,, if you are doing heavy driving with heavy power then SVG 75W110 would be the ticket
Old Jan 16, 2010 | 08:02 AM
Deathevn's Avatar
I've been using the 75w90 in my 6 speed. Notchy going into 2nd when it is cold, but is really smooth once it is warmed up a little. The stock OEM was notchy going into 2nd as well. I also change the fluid every couple thousand miles due to road racing it, so no clue on how long it lasts.
Old Jan 16, 2010 | 08:22 AM
MR White's Avatar
So normal shifting my 6sp is smooth as butter but shifting fast at higher rpms I always get some grind in 2nd. Can tranny fluid help this? I had the first manual tranny fluid change at 28k (bought car used) but I'm going to change every 12k going forward. Last change was done at dealership so I think it was diaqueen, felt great at first but the grind came back. Suggestions?
Old Jan 16, 2010 | 08:27 AM
SpeedingEvo's Avatar
I have been using the AMSOil for about 15000 miles and love it, it is a bit notchy in sub freezing temps for like 5min on startup, but I had the same prob with the OEM and the OEM would grind at high rpm shifts even warmed up, dont have that problem with the AMSOil. I won't use anything else.
Old Jan 16, 2010 | 05:03 PM
apagan01's Avatar
some also forget about the agresiveness of the evo trannys, syncros are a bit more agresive than some are accostumed to.
Old Jan 17, 2010 | 05:02 AM
kambodianboi's Avatar
Im about to change my drivetrain fluids soon, leaning toward using Redline. I have a 5sp transmission.
I just dont know which combo should I use...
2 quarts of MTL and 1 quarts of MT-90 - Transmission
1 quart anti-shock - Center Differential
1 quart of 75W90 - Rear Differential
Or
3 quarts of MT-90 - Transmission
Old Jan 17, 2010 | 05:32 AM
Peter Tiebout's Avatar
Silkolene Syntran 5. trans/diffs since 3K miles with no issues. 30+K on car currently..Pete
Old Jan 17, 2010 | 09:52 AM
mrfred's Avatar
I've tried Diaqueen, Amsoil MTG, and Amsoil SVG in my MR gearbox. Still have 1st->2nd slight grind with all of these. Its been a while since I've run the Diaqueen, but my recollection is that the MTG gave a bit better shifting performance. The SVG gives about the same 1st->2nd shifting performance as the MTG, maybe a tad bit worse. Haven't tried the Castrol... perhaps I'll try it for the next gearbox change, but with Amsoil's great reputation for wear resistance, I'm tempted to say that I'll sacrifice some 1st->2nd gear performance in exchange for an oil that has the best gear teeth protection.
