Help! Broken Downpipe bolts
Old May 31, 2013 | 06:56 PM
Poogy44's Avatar
Question Help! Broken Downpipe bolts
Swapping out the clutch of an Evo 8 and when I was taking off the down pipe I snapped both bolts off by the manifold. I know how to attempt to get them out, but I need some ones help telling me what size and where I can get these bolts. Thanks and please help.
Old May 31, 2013 | 07:13 PM
cpunlamd's Avatar
This is not going to be an easy fix. Being that you don't know the solution, I'm going off on a limb here and assume that this task to fix these bolts will be too difficult for you to accomplish.
Have the car brought to a professional. The bolts will either be drilled out or the person have weld a bolt to what ever is left (if long enough) and remove it after.
Old May 31, 2013 | 07:48 PM
Poogy44's Avatar
Thanks for your input, maybe I should rephrase my question. Once I tap these two bolts out what size and where do I buy 2 new ones. Thanks in advance.
Old May 31, 2013 | 08:50 PM
Piro Fyre's Avatar
Blow torch and vise grips works well if there's still a stud sticking out.
Stick with OEM bolts for the down pipe. You can get them at the dealership.
Old Jun 1, 2013 | 08:06 AM
Poogy44's Avatar
They're like 40 bucks anything out there cheaper?
Old Jun 1, 2013 | 01:02 PM
cpunlamd's Avatar
There really is no replacement for the oem bolt in that area. Your best bet is to contact Peter@JNZtuning, Russell@mitsubishiparts.net, or Jomer@FredBeans.
They can get you oem parts a lot cheaper than your local stealership.
Old Jun 2, 2013 | 10:58 AM
InfamousEvo's Avatar
Don't cheap out on bolts dude, you're just asking to break more of them... The OEMs are expensive but really your only option to retain factory strength/reliability. Home Depot bolts might be a good temporary fix, but they won't hold up long-term.
Old Jun 5, 2013 | 01:17 AM
4AGT_86's Avatar
Just drill out the holes just enough to slide a bolt through. Use high grade/strength nut, bolt and washers.
Old Jun 5, 2013 | 01:04 PM
PureDrivePerformance's Avatar
Do you mean you snapped the bolts that go to the o2 housing?
If so, I've done that on the OEM o2 housing. I bought an aftermarket o2 housing and used SS bolts with fender washers and reused the spring. Eventually I got the OEM ones. I used the bolts for several years without any problems.
spooln3
North Texas Evo Club (NTEC)
Jun 9, 2013 07:39 PM
xtruemassacre
10
Jan 29, 2013 01:43 PM
5LEEPERISAH23I
Sep 28, 2012 08:37 AM
reboundicon
Apr 20, 2011 04:20 PM
rgar
Jul 8, 2010 04:39 PM
