Broken bolt for manifold heat shield, removal advice?
Old Apr 20, 2011 | 10:15 AM
reboundicon's Avatar
Angry Broken bolt for manifold heat shield, removal advice?
Hey guys,
I was installing a new ARC manifold heat shield and as I was removing the bolts that hold the OEM manifold shield in place, the head of one of the bolts broke off. Probably because they were fairly old and worn due to all the heat from the manifold, and applying too much pressure.
My question is:
1. Do you guys have any tips or tricks to removing this broken bolt as I've seen tricks from welding another head to the bolt and people that use bolt extractors. I've heard mixed reviews about both and want to get it out as quick as possible.
2. Will I be fine just leaving the broken bolt in there or is it possible it will weave it's way down into the manifold from vibration?
Any help is appreciated as this is very annoying.
Old Apr 20, 2011 | 10:19 AM
06MREvo's Avatar
Sounds like a good time to get a ported & coated stock manifold and use this one as a core...
Old Apr 20, 2011 | 10:27 AM
mdsevo06's Avatar
^this does not answer the question, I'm sure the OP knows this opsion. I have one as well in an already ported and coated Mani. and was going to use the bolt extractors route.
Old Apr 20, 2011 | 10:33 AM
06MREvo's Avatar
Thanks mom...and actually it is an answer to his question, just another way to answer it...
OP, there have been a couple threads like this lately...search button...
Old Apr 20, 2011 | 10:42 AM
mdsevo06's Avatar
More useful information Son....Search
Old Apr 20, 2011 | 10:46 AM
Yup, I've checked the search (like I always do haha) and couldn't find anything super helpful. I know there are extractors and some guys weld a head on to it, but I'm wondering if there are any tips and tricks or am I better off just leaving it.
This does make a new manifold set up seem tempting, but don't really want to spend $300 for 1 broken heat shield bolt at the moment.
Old Apr 20, 2011 | 10:48 AM
How long has yours been sitting in the hole for the manifold shield? Any issues with it weaving down more or has it been sitting in the same spot since it happened?
Old Apr 20, 2011 | 10:49 AM
estevo9's Avatar
Try the bolt extractor, but just try to drill the hole right in the middle, and deep enough...should work, you can also try heating it before you take it out.
Old Apr 20, 2011 | 10:53 AM
mdsevo06's Avatar
It's been there for almost two years, it's going no where. The mani. is silver coated and was going to remove and have it black heat treated and have the supports shaved at the same time. Bolt remover should work and don't cost much.
Old Apr 20, 2011 | 11:12 AM
Good to know someone is in the same boat as me lol. Have you tried a bolt extractor on it at all? I've seen some guys do it with success and others who have failed and ended up breaking the bolt completely.
I'll pick up an extractor kit and see how it goes soon.
Old Apr 20, 2011 | 12:08 PM
revvin9k's Avatar
Your best bet would be a machine shop.... those cast manis are no joke....especially when a bolt snaps in em.
Old Apr 20, 2011 | 04:20 PM
elementsk8erq's Avatar
You can try welding a nut on the stud and turning that thing outa there.
haxr303
Jun 4, 2018 08:16 PM
hamburger_train
Evo X How Tos / Installations
14
Mar 4, 2014 10:35 AM
Webman
19
Mar 22, 2013 07:23 PM
Randal
12
Jan 24, 2013 07:19 AM
