Piston hitting plug?
Old Apr 28, 2018 | 11:22 AM
ign 5's Avatar
Originally Posted by 2006EvoIXer
What do you mean by "deep"?
Bassy, not like a normal pop like backfire that these cars usually get, but way deeper pitch, subwoofer deep, like 40 hrtz lol I am not sure how to explain, like I assume a flame came out.
Old Apr 28, 2018 | 11:51 AM
2006EvoIXer's Avatar
maybe your cylinder didn't spark so unburned mixture got into exhaust manifold and next exhaust came into manifold still burning and ignited that mixture in turbo?
Old Apr 28, 2018 | 12:02 PM
If your spark plugs are shorter than oem ones, adding washers would pull the tip further out of combustion chamber. I don't see how that can help. Lol
Old Apr 28, 2018 | 12:38 PM
ign 5's Avatar
My logic is, if it is higher up, and it is because middle of pistons are dirty, they will not be able to make contact if higher up. Spark plugs regapped, new washers on, installed, started..running fine....but for how long.
Old Apr 28, 2018 | 12:52 PM
I agree with barneyb that it is more likely detonation bent your plugs than 8mm of cabon buildup on your pistons. 8 mm of buildup is a serious massive gunk that will throw off your engine balance. Lol
Old Apr 28, 2018 | 03:08 PM
kaj's Avatar
kaj
Starting with simple first: Do you drop the plugs into the head when you install them? If they bump the head on the way down, that could close the gap. I've seen it happen, so I always lower them down in a spark plug socket.
Old Apr 28, 2018 | 03:28 PM
barneyb's Avatar
What about being tuned on 93, and driving on 91 as no 93 in Vegas? I get some DEEP backfires at times while decelerating at times. Injectors are factory, non upgraded at all.
Just did the magnet test, nothing in there. But, it gave me a chance to really feel the pistons, and they are very carbon, feels like asphalt in there, atleast number 1 and 4, the others are smoother, but still like sand paper. This is soo odd haha. I am very fast at pulling the plugs though now, so that is a plus. I am not worried that I bend the gap back and forth so much it is gonna break off eventually. Pulling the whole head really does not look too hard on this car, but currently my only car, so it would be a pain finding time to do it.
I never before heard of a 4g63 engine piston hitting the spark plug.
Your engine may be in a danger close situation. Gasoline is supposed to burn in an engine. If it explodes, the shock can break things and bend the electrode on the spark plug. What it breaks is usually the piston. The wrong octane, heat, and a cylinder pumping oil are causes of detonation. The main cause is a lean mixture. That is why I suggested a fuel injector problem.
A good shop will have the ability to flow test the injectors.
Old Apr 28, 2018 | 06:05 PM
Do you have pictures of your old plugs? Post them if you do.
Old Apr 29, 2018 | 10:40 AM
LetsGetThisDone's Avatar
Of your car is tuned for 93, running it on 91 is asking for problems.
Old Apr 29, 2018 | 07:18 PM
Good catch. I missed that when chauffeuring wife and son (didn't know that's what comes with marriage ).
Try adding octane booster to see if that helps. I like the turbo 104.
Old Apr 30, 2018 | 07:53 AM
ign 5's Avatar
No, I am rather careful, but, lets say I did drop them, and it caused the bend in gap, Why would it run fine for hour/days/week before it starting to misfire and have an issue?
Old Apr 30, 2018 | 07:59 AM
ign 5's Avatar
I asked the local tuner about it, (the 91/93 thing) and he said I do need to get tuned, but that difference is not a big deal, just dont do super long like 3rd gear pulls etc. The car is new, so I tend to get on it every now and then, but just crusing, under 3500 rpm may cause this? I am not doubting, just asking.
Update, added double washers to all the plugs, ran like total crap, took the washers off 2 and 3, as they never had a problem, and it is running best it ever has. Very strange. Been only 2 days, but so far so good. I agree makes no sense, but it is working. I have all teh teals I need to adjust the gap with me at all times now, will keep you posted.
Old Apr 30, 2018 | 08:08 AM
So double washers probably pull spark plug tip completely out of combustion chamber.
It's possible that under light throttle, timing is too advanced for 91. Try good quality octane booster until you get retuned for 91. The difference in WOT maps may not be much but light throttle runs fuel hotter for economy and that could be significant in timing.
Old Apr 30, 2018 | 08:29 AM
kaj's Avatar
kaj
Actually, that wouldn't make sense. I missed that part of your post, sorry. I was hoping it would be something easy LOL.
The fact that the washers helped is a definite warning sign. You really need to figure out what's going on, as you already know. All four plugs are the same? This is just weird.
As for the tune, staying in closed loop should be fine. Just don't give it much gas or rev it much and get it tuned asap.
Old Apr 30, 2018 | 08:50 AM
ign 5's Avatar
Yes, that is correct, they are all the same size, soo strange, but i think this detonation might be it, it almost has to be. I just took it around the block and i got on it, let of and pressed in the clutch to let it go down to idle while coasting, and it did a very quick backfire and back to a misfire. I will check and fix when I get off work. Detonation has got to be it right? Plugs get hot and more flexible, then backfire bends them, right? haha
