Jerks and quirks
Do you have the means to pull a log from the ECU? If you can, post the log up here & the guys can take a look at it
Ultimatley, It might be best to source out a tuner (a competent one!). Even if you have to travel a bit to get there
Engine bay looks good & well sorted but needs a detail for sure.
How many KM on are on it. Might be time for a major service & tune
Cheers
Cheers
The car has 52000 km on it. Will try to get the software for the piggy back today and see if I can get the log myself (hopefully I don't mess it up).
I sort did have a similar problem as the car jerking a WOT or even partial open throttle. To me it could be your injectors, do you know the size and how long they been in the motor. I just swap mine to high impedence WOW the car is smooth no more jerking and also a good tune. My prior injector were low impedence with is horrible for street driving and way to big 1800cc. I change to 1300cc it great! I had did every check you did for me it was my injectors. Injector might just need to clean. Probably a lot residual stuff in the fuel try that first.
caz3126 (Jun 15, 2018)
Thanks for all the help so far guys. Every bit of advice is greatly appreciated!
Finally got my MAF sensor almost 2 weeks now..the car is a lot better..boosting seems to be on point, had a boost leak test done, it's sealed tight..however with the new maf in, the engine is missing, I need to get around to checking the spark plugs gap.
any suggestion to how much I should gap them? And if the gap is fine and its still missing, what else should I check?
The delay at 4-5k is still there but not as bad, so I'm wondering if whatever is causing the miss, is cause that, I'm usually boosting at 18psi exact, on a hard run with good cool air, I've peaked 18.4.
As for the piggy back log, the day I finally got xp on the laptop, the next day the laptop crashed and that was the end...then I couldn't get into evom.net..finally got in the few minute before typing this..lol..thanks again guys, seems like these cars are never fully sorted, so I look forward to suggestions
The best way is to log the car.
Reading your posts i suggest to have a look at your fuel pump also.
Convert to SD , you will love the drivability and smoothness.
gap .022
BTW the your hesitation I believe maybe fuel pump it don't think so more like your coil pack! Are you still on the original coil pack?
You check the spark plug but for me the key is that at 18psi that when problem start as you build boost it s harder for the ignition to happen.Need to have good conductor if it is the original coil pack it time to replace them. I would get a Spoolin up cop. If you have a friend with an Evo swap with him and try to do a pull. and see what it does for you.
caz3126 (Sep 21, 2018)
sorry for the late reply. I will definitely try my friend's coil pack from his Evo 4. I have no idea why i didn't think of that sooner. If that doesn't work I had my mind set on a WALBRO. Gosh it is so expensive to get parks here, but I am going slow n steady.
Thank you for the advice.
EVO196 (Oct 3, 2018)
caz3126 (Oct 3, 2018)
Very sorry i didn't reply, I could have sworn I did. I gap the plugs @ 0.25 on the gauge I have, and it has improved the breaking up. Very rarely i would break up on a good run, but nothing as hard as before, and I notice it comes more when I go full throttle. The tip of the plugs are black when i took them out. I took a look at the coil packs, and they look almost new (ralliart packs). Also did an oil change although I did one 3 month ago (Mobil 1 10w30 full syn). Would be doing another change hopefully the end of this month, because what i got out was filthy.
