Hallman bc w/ pics or location?
Old Apr 8, 2004 | 06:55 PM
Tracer's Avatar
Does anybody have any pics of the hallman, or pic locations? Curious how hard it is to install. I am thinking of going with this instead of ebc, also do you have to adjust it w/temp changes?
Old Apr 9, 2004 | 03:58 AM
Bom's Evo's Avatar
not a hallman, but its an mbc.
its a Perrin Mbc. my friend made a little bracket for me just like the one on the radiator. i just doubled it up and used the same bolt. right now i have it set to 19psi , with a 20psi spike. i've had it this way for 70degree weather and 25 degree weather. The mbc holds steady through that w/o changing anything.
the hallman will be alittle bigger. and is much easier to dial in with its knob. i originally started with it ziptied to the battery bracket, but the hoses we really too long. this is right there next to the compressor nipple and wastegate.
its really easy to install, i just needed to remove the airbox and yank some hoses off.
MBC is worth every penny
i have a greddy profec b spec 1, black, for sale $200. that comes with a box where u make ur hose connections and u run the wire to the boost controller. PM if your interested.
bom
Old Apr 9, 2004 | 10:02 AM
SuperchargedGTZ's Avatar
here is one
Attached Thumbnails Hallman bc w/ pics or location?-hbc-mount.jpg
Old Apr 9, 2004 | 10:04 AM
another
Attached Thumbnails Hallman bc w/ pics or location?-hbc-knob.jpg
Old Apr 9, 2004 | 10:07 AM
prowler's Avatar
Hmm, not a great shot, but here is my control knob. The BC installation is very hard to spot out in my engine bay, it was hidden nicely.
Attached Thumbnails Hallman bc w/ pics or location?-dsc02544.jpg
Old Apr 9, 2004 | 10:58 AM
JustDSM's Avatar
Here's the installation of my Hallman PRO. I fabbed up an aluminum bracket which positioned the valve in a location that kept it away from major heat sources and kept the source/outlet lines as short as possible (also keeping them away from heat sources).
Old Apr 10, 2004 | 03:06 AM
moogle's Avatar
ooh sleeper.
