Intermittent starting issues (driving me crazy)
Old Jul 24, 2018 | 07:58 PM
imissmyhonda's Avatar
Car is a 06 MR with around 44k miles on it, this thing is my baby and it is well taken care of.
Lately, I’m having occasional starting issues. About 80% of the time, it starts right up.
But it’s getting pretty hot here right now, and I’m noticing the issue getting worse....
Basically I’ll turn the key forward to start it, and I will hear a click of some sort but no crank. I will try repeatedly to start but it just won’t. Then out of the blue, it will finally crank and start right up.
Today, I took it to the tire shop. It started right up without any issues. However, when they went to start the car to move it into the bay, it would not crank over. Basically acted like a dead battery, but all my accessories turned on, etc.
We eventually had to push start it, as jump starting does not work when it does this.
I’m super frustrated and just want this thing to start when it’s supposed to.
I have replaced the following:
battery
ignition switch
spark plugs
and I checked all the connections too
Could this be a starter issue? My starter doesn’t make any weird noises.
Old Jul 24, 2018 | 10:47 PM
patric78's Avatar
Hi, did you already check this link?
Cheers,
Patric
Old Jul 25, 2018 | 07:16 AM
Cheers,
Patric
I replaced the ignition starter switch with a brand new one from Mitsubishi. But still having the issue, especially when it’s hot outside and the car is hot.
Since my issue yesterday, I’ve started the car more than a dozen times and it has started every time with no issue. So it’s fairly unpredictable.
Old Jul 25, 2018 | 09:13 AM
wht95scort's Avatar
You have a "dead spot" in your starter. Replace it.
Old Jul 25, 2018 | 04:27 PM
Got a new one one the way, hopefully that does the trick.
Old Jul 26, 2018 | 11:50 AM
Jrah2987's Avatar
Veteran: Air Force
Did you secure the ignition switch to the steering column with zip ties, test the starter relay, disable the clutch switch, use a jumper cable from pin 5 to the battery while the issue is happening, check the connections on the starter for corrosion? I replaced a bunch of parts (starter included) and the problem wasn't fixed until I installed that heavy duty relay mentioned in that thread.
Old Jul 27, 2018 | 12:28 AM
Ignition switch is secured w/ zip ties. Clutch switch has been disabled for years. No visible corrosion anywhere, the car isn’t driven in the winter or rain.
As far as the electrical stuff, that’s beyond me. I saw in that thread they wired in a relay but honestly that’s not something I’m familiar with.
Its weird because after I replaced the ignition switch, I didn’t have the issue for weeks.
But now it’s back and happening more frequently with the increase in temperature.
Old Jul 27, 2018 | 10:04 AM
Jrah2987's Avatar
Veteran: Air Force
Oh, yeah I understand not wanting to mess with the electrical stuff. I'm the same way, but my no starts became more and more frequent over the years until I got desperate enough to try it myself. Trying the jumper cable method is very easy, however, and will make sure you don't get stranded anywhere (assuming you're having the same voltage issue a lot of us have had). Just get a 14 awg wire, strip both ends a bit, put one end in pin 5 of where the starter relay goes (picture on the last page of that thread) and touch the other end to your battery positive terminal. Make sure the car isn't in gear when doing this. I had to do this about 5ish times, and it worked every time for me when the car would just click.
Old Jul 27, 2018 | 11:12 PM
FRESH.I.AM's Avatar
I have the same issue with my evo replaced battery, starter, ignition switch and alternator. I still sometimes just get a click when i try to start my car. Most of the time I'll have to put the car in gear and rock it back and forth then it will start. Im going to try to replace the starter relay and see if that helps.
Old Aug 7, 2018 | 08:22 PM
Update:
Replaced the starter and haven’t had any issues so far.
Old Aug 8, 2018 | 06:35 AM
fafaforza's Avatar
How did the wiring look? On my 03, the power lead was frayed. It was hanging on by like 4 strands out of however many there are, so I had intermittent starting too. It might start if you bumped it a certain way, like an old TV. I re-crimped it and no issues since.
So check the condition if you still experience issues.
Old Aug 8, 2018 | 06:41 AM
The wiring looked great, I didn’t spot any corrosion or fraying.
I don’t know, maybe the old starter had something going on internally, I’m not sure.
Just glad it’s starting all the time now. lol
Old Aug 9, 2018 | 08:45 AM
EVO196's Avatar
I had the same issue, I replaced the starter & it started with no problem but the problem is back. I'm going to try the starter relay & starter switch
Old Aug 9, 2018 | 06:02 PM
okevolutionVIII's Avatar
Use ECUFlash to disable the ignition immobilizer and then try it
Old Oct 1, 2018 | 07:04 AM
ultm8mind's Avatar
Veteran: Army
I have the error code "Incorrect Immobilizer Key" now that you mention it okevolutionVIII... I am having the same issues, by the way and replaced battery today and issue was still there.
