urgent oil press gauge install question
Old Apr 9, 2004 | 07:58 AM
d15b7's Avatar
hi fellas.
was up last night late installing a full complement of gauges.... got everything installed with the exception of the oil pressure gauge -- i don't have the right sized adapter to screw it into the oil filter housing. i removed one of the hex pipe plugs (one of two) in the filter housing, and boy o boy was that tough to get out! problem is, i don't know what size adapter to go try to buy? i know its not 1/8"npt, i am pretty sure its not 1/4" npt; so what size do i get? the male end needs to screw into the filter housing, and i need a female end that is 1/8" npt so i can connect the gauge.
thanx in advance!
todd
d15b7@aol.com
Old Apr 9, 2004 | 06:09 PM
d15b7's Avatar
anyone???
Old Apr 9, 2004 | 06:30 PM
asdf's Avatar
I used a 3/8 NPT to 1/8 "bushing" from Ace Hardware in the pipe fitting section. Worked perfect because it didn't stick out too much. Don't forget to use teflon tape.
I recall an old thread on this topic exactly. Might be worth a search.
Old Apr 10, 2004 | 08:52 AM
d15b7's Avatar
thanx! on my way out the the hardware store now!!!
todd
Old Apr 10, 2004 | 09:58 AM
freedom's Avatar
todd
You might want to check out this thread. The Evo is BSPT, not NPT.
Thread a NPT fitting in there and you will mess up the threads. So if you use the NPT fitting make sure you use a sealer on the threads as it won't be the taper sealing the interface.
jid2
20
Sep 7, 2020 01:22 PM
dtfrost5
May 13, 2016 06:33 PM
EGbeater
34
Mar 1, 2015 09:52 PM
rrstlevo
Nov 23, 2012 08:58 AM
newbiewonkenobe
Aug 19, 2006 07:57 AM
