Car in gear isnt moving
Installed a QuarterMaster Hydraulic Release Bearing and went to drive the car and clutch is all the way out and in gear and car isnt moving. Put it in reverse and gave it some gas and it creeped a little. Thinking it may have been shimmed too much any thoughts. Or has anyone else had this issue?
you installed a quartermaster clutch also? or just a hydraulic release bearing?
if you put in the whole entire kit... did you measure ?
mine was dead on with no shims.
however, something dont sound correct. something is pushing the clutch all the way in .... and i dont think there are enough shims in the kit to make it that bad off.
when you bolted up the tranny, did it seem hard to run all the bolts pulling it up to the motor?
it almost sounds like something is not lined up right or something, and when you bolted everything up it has pushed the clutch in.
you didnt have any issues getting the basket tighted down nice and even did you?
