24 pounds of boost.
Old Aug 15, 2018 | 06:01 PM
Bzacharias's Avatar
24 pounds of boost.
So after 2 years of driving my car I just noticed today that in 4th gear I can hit 24lbs. Is this something I should worry about on pump gas? Every other gear seems to be about 21lbs. Motor has manly rods, and can’t remember my pistons off the top of my head.
Old Aug 15, 2018 | 06:48 PM
hutch959's Avatar
as long as its not knocking... let it rip
Old Aug 15, 2018 | 06:56 PM
Bzacharias's Avatar
lol don’t want it to knock. Has under 10k on the motor.
Old Aug 15, 2018 | 07:16 PM
When was the last proper tuning session?
Old Aug 15, 2018 | 07:32 PM
Bzacharias's Avatar
previous owner probably. Was trying to avoid that for now. But after today things seemed a little scary.
Old Aug 15, 2018 | 08:12 PM
A solid, clean tune is the answer, especially w/your freshly built motor. Dont chance an expensive mistake
Old Aug 15, 2018 | 08:22 PM
Bzacharias's Avatar
I was hoping to get cams first. But haven’t wanted to spend the money right now. But I guess I might have to.
Old Aug 15, 2018 | 10:18 PM
SnailSpeed's Avatar
It depends what setup you have but providing that timing isn't too high and your afr isn't too lean you should be fine on 24psi on 92 octane. I personally run 27psi peak on my stock turbo setup on 92 octane. Get a tactrix cable and learn how to use evoscan, only way to tell if its fine or not.
Old Aug 16, 2018 | 11:59 AM
Bzacharias's Avatar
what all do I need for evo scan? I have a cable of some sort in my glove box.
Old Aug 16, 2018 | 12:39 PM
Teal2nnr's Avatar
Start reading in the tuning section of this forum. Most of your questions have probably already been answered. The more you understand about your car the better off you are, even if you never touch the tune yourself.
ecu flash / evoscan is a program used to flash the stock ECU. It's how you can manipulate the stock tune on the car.
Old Aug 16, 2018 | 01:09 PM
Bzacharias's Avatar
alright. Just not sure where to get the equipment. Looked in a few places but always came up empty
Old Aug 16, 2018 | 06:53 PM
SnailSpeed's Avatar
Tactrix open port 2.0: https://www.tactrix.com/index.php?op...ed=1&Itemid=53
Back when I purchased mine, evoscan was included as part of the tactrix cable purchase. I don't know if that changed, if it did you can buy it from the same website and it should be around $26 or so. If i were you I would also add the Mitsubishi flash adapter so that you can read and write your ecu.
Old Aug 16, 2018 | 07:03 PM
hutch959's Avatar
let me clarify my comment...
I didnt mean ... if you dont hear the motor knocking, let it rip.
I meant, if you dont see any signs of knock in the logs, then let it rip.
Need to be logging to see really if the motor is safe or not.
Old Aug 16, 2018 | 07:09 PM
Bzacharias's Avatar
oh alright al check into all this.
Old Aug 16, 2018 | 08:24 PM
Bzacharias's Avatar
am I gonna need a reflash adapter?
