Trying to figure out a problem. Please help !
Old Aug 25, 2018 | 01:54 PM
1nf3rn0's Avatar
Hey guys ! Im trying to figure out whats going out with my evo 8.
So the thing is after i hit peak boost, throught any gears, about 30 seconds after the car starts to lean out and shuts off, by that i mean after im done doing the pull and i start cruising normally. Through the high boost pulls, it could be, gear 2,3,4(it doesn't matter) it runs fine, the AFR's seems to be all good, it doesnt run lean at all, but after i stop running the car in high boost, maybe 30 seconds after, it start to run lean on the AFR and shuts off, if i turn the ignition off and start it again it runs for about 30 seconds and shuts off again. I have to wait about 15 minutes until i can drive the car again so it doesn't shut off. Im running a dual pumper with an AEM series 1 with a built motor and a tune done not long time ago. Im guessing that the dual pumper needs to be rebuild.
I read the article about the return line needing to be drilled out(i have the same problem of it running like its running low while theres still quarter of a tank left. Im not sure what could cause this lean out after hitting boost, specially if the AFR is in normal range while its in boost. Please help and thank you !
Old Aug 31, 2018 | 06:34 PM
CDrinkH2O's Avatar
Dirty fuel filter? Pull the hanger and check it. It is in the white plastic above the pump and cannot be changed without buying the whole hanger.
Old Aug 31, 2018 | 08:34 PM
hutch959's Avatar
install a fuel pressure gauge on the rail... and then you will know if fuel pressure is the issue.
Old Sep 1, 2018 | 05:18 PM
1nf3rn0's Avatar
Thank you guys im planing on doing a fuel pressure check monday, hopefully that will clear things up
Old Sep 2, 2018 | 04:00 AM
1nf3rn0's Avatar
How will i know if its dirty, can you tell visually, ?
Old Sep 2, 2018 | 06:23 PM
hutch959's Avatar
not really.
you can blow through it... if its hard to blow through it, its clogged.
