Evo 9 leak/compression bad
Old Sep 19, 2018 | 08:48 AM
kilam09's Avatar
So
these are the results of my tests. Now I was wondering what you guys would suggest, I was thinkin of when I go on deployment next year just take the engine out send it to a shop and rebuild it but that’s not anytime soon. I’ve had people also suggest to buy a stock engine but I have no idea where to start to find a decent stock engine that’s not busted up so any helpful thoughts would be helpful thank you !!!
Old Sep 19, 2018 | 10:14 AM
2006EvoIXer's Avatar
It all depends on your budget. If you have the money to build, that's what I would do. If not, then you can get a brand new stock block from dealer, and have a shop refresh your head and put back together with new timing components & water pump for about $4k plus your mechanic labor charges. Also, have your injectors cleaned while engine is out.
Old Sep 19, 2018 | 12:16 PM
kilam09's Avatar
Oh and I also seen used jdm engines for sale on eBay for $1900 would you take a chance with that or no?
Old Sep 19, 2018 | 01:23 PM
If you can trust the engine is good and know how to fix if bad, then you can risk it and save $600-$1000. But I'd rather buy from dealer and know that short block is good with zero miles
Old Sep 19, 2018 | 02:02 PM
kaj's Avatar
kaj
If they can verify mileage. These engines are pretty hard to kill, so chances are it would be okay. Saving $1,400 would be pretty danged nice.
Also: Are they saying you have 0% leakdown on the other cylinders? That would be impressive. And the first row of numbers is compression? I'm trying to make sense of the readings.
Old Sep 19, 2018 | 03:55 PM
kilam09's Avatar
yes 0% on 1,3,4 and 60% on 2. I DO want to avoid buying a brand new engine for $5000 because in the end I’m going to wanna build it up so I will probably call up the company “jdmenginecorp” and verify the health and etc
Old Sep 19, 2018 | 04:23 PM
kaj's Avatar
kaj
$5000???
Old Sep 19, 2018 | 04:59 PM
Who's selling a brand new engine for $5k?
Old Sep 19, 2018 | 06:09 PM
kilam09's Avatar
a Mitsubishi dealership... unless there’s cheaper elsewhere if so link me !!
Old Sep 19, 2018 | 06:12 PM
I've been told that you won't find a new long block. But they still have new short blocks.
Old Sep 19, 2018 | 06:59 PM
kaj's Avatar
kaj
Unless your head is toast, a shortblock is only $3300 shipped from STM.
Old Sep 20, 2018 | 07:34 AM
barneyb's Avatar
Also trying to make sense of these numbers. The best prepared engine on earth will leak down around 6%.
Old Sep 20, 2018 | 08:07 AM
kaj's Avatar
kaj
That's what I was thinking. I think I'd go to a different shop and get a second opinion.
