Rear Diff service required? 165k miles before Weir 12 plate
Old Sep 26, 2018 | 02:09 PM
SilviaVsSupra's Avatar
Hey folks.
I have a Weir 12 plate to install on my current rear diff. The car has 165k miles.
Do I need to account for the wear on my ring & pinion when I do the clutch pack install? I don't want to be messing with the backlash, I've seen how pita it is.
Hoping I can just R&R with the new clutch pack, but I don't think I can, with a clean conscience, knowing that the rear diff has seen 165k butt kicking miles.
If R&R is advisable, I can do it myself. If not, I'll have a competent driveline shop do the install and adjustments but I would like to gather the necessary OEM parts before taking it to them.
Thanks in advance for your advice.
Old Sep 26, 2018 | 02:18 PM
Pal215's Avatar
How bad is the gear lash right now? You could probably get away with throwing the clutch pack in and calling it a day without any problems. The evo's rear diff lasts a long time. The WEIR 12 plate is a ton of fun, but it will wear out faster than the TRE 12 Plate max lock service. That being said, I run the weir set and can still get the car to power oversteer after 15,000 miles of use.
Old Sep 26, 2018 | 02:29 PM
blackline's Avatar
5 Year Member
It might be easier to send the diff and plate kit to shep. Removal of the diff is pretty straight forward.
This is what shep quoted me a few weeks ago.
We can do a stock rebuild or restack (your choice) for $250 or rebuild + 12 plate upgrade is $350. We replace all seals, bead blast, paint, re-shim etc.
This price doesn’t include any bearings, if any bearings or other parts would need replaced the cost can increase
and I've been having a hard time getting in contact with TRE...
Old Sep 26, 2018 | 03:29 PM
kaj's Avatar
kaj
TRE is really hard to reach; I recently had to send my trans to Shep, since I could reach John.
on the bright side = 2-day turn around and it'll be here tomorrow!
I'd REALLY like John to do my rear diff, though. When I'm ready, I'll try once more.
As for the Weir: it's a drop in. If the differential needs any adjustments, It won't be due to the clutch packs; It would be a pre-existing issue.
Old Sep 27, 2018 | 06:20 AM
Going to contact them today to see if they can help me out. Thanks for the tip
