4G64CRANK on my EVO 6
Old Oct 16, 2018 | 10:51 AM
febyzaoldyeck7's Avatar
now im started for using this kit
4g64 crank 100mm
tomei stroker piston 85.5
tomei rod 147mm
question is .
is installing 4g64 crank into 4g63 block need some attention? like grinding to prevent hit something?
Old Oct 16, 2018 | 12:36 PM
LetsGetThisDone's Avatar
Using a 147mm rod is a terrible idea. Several companies make stroker pistons to use a 150mm rod in this setup,
And yes, mock-up should be done to check clearance of the rods to the block.
