Advice on 250kw build
Old Oct 28, 2018 | 04:46 AM
EVO01M's Avatar
Lightbulb Advice on 250kw build
Recently got an Evo and would like to hit the 250kw mark, I know E85 is essential so I'm guessing 1000cc injectors and a fuel pump with a tune will be fine. But will I need anything else to be safe or will that be good to go.
Old Oct 28, 2018 | 05:09 AM
I run 1000cc injectors on E85 but im maxed out. You should consider larger! You will also need a 3 port boost solenoid needed for the ECU tune
Old Oct 28, 2018 | 11:27 AM
LetsGetThisDone's Avatar
250kw is 330whp. Gasoline should be fine for those numbers, and really won't need larger than stock injectors. Maybe bump up to some 700 or 800's just to have some headroom. 1000's with E85 will make 400hp on the stock turbo no problem.
Old Oct 29, 2018 | 07:55 AM
EVO01M's Avatar
E85 tune Evo 7
Couple of questions
Can you do a single map E85 tune on the stock ecu
Also thinking of just buying the xspurt Bosch 1000cc injectors, do I need to upgrade any hoses or the rail to go along with them
Thanks
Old Oct 29, 2018 | 09:36 AM
Most of us run a dual tune on the stock ECU (93 & E85)
No need to upgrade any of the fuel hoses or the fuel rail. As i noted above, been running RC1000's for many years on E85 (460 Dynojet WHP)
