1000cc install need tune right away?
Old Oct 28, 2018 | 12:33 PM
twinkie_mayne's Avatar
Hey guys just upgraded my 880ccs to 1000cc injectors. Will it need to be tuned right away? Or will i be able to drive it? Car is currently at my buddies so will need to drive an hour home and then an hour to the shop to get tuned next week.
Old Oct 28, 2018 | 12:41 PM
LetsGetThisDone's Avatar
They're close enough it should be ok. Just stay out of boost. May have some drivability quirks, but it won't hurt it.
Old Oct 28, 2018 | 12:46 PM
Biggiesacks's Avatar
It won't hurt it, but drivability will be *** so make sure your battery is in good shape because it might stall a bunch. Also if the trims can't adjust enough for it you will be running pretty rich, so bring some new spark plugs with you to the tuner.
Old Oct 28, 2018 | 12:47 PM
We ended up tinkering with it so it idles pretty good. Was planning on just keeping it out of boost on the way home and to the tuner.
Old Oct 29, 2018 | 10:50 AM
slocho's Avatar
I went from stock injectors and pump, to 1050cc and 255 pump. I drove about 200 miles to my tuner. I just stayed out of boost.
the only thing i noticed was it was hard to start sometimes and the check engine light came on with a running rich code. Other than that, no issues.
