Turbo Timer caused electric malfunction????
Just got my TUrbo Timer installed, and when i was cruising today... and i tried to pull back my sunroof... it wouldn't go back. It would pop up, come down, but when i want it to move back.. it doesn't move. It makes a sound like its attempting to move, but it just won't. Is it possible its the turbo timer installation?
Plus i just added my RMR induction pipe without unplugging the negative. I couldn't find my 10mm wrench bolt thingy.... could not resetting the ecu cause a malfunction after i added the pipe?
I really don't wanna to take it in and have it tried to be covered under my warranty... shiet.... i don't know what to do. I can't get my warranty screwed bc of a ****ty installation of my turbo timer. But i got it professionaly done....
im lost.......
im lost.......
Re: Turbo Timer caused electric malfunction????
im lost.......
im lost.......
Disconnect your negativer terminal before you unplug anything. You never know what might be hot and mitsu
will tell you to phuk yourself if you show up with a botched electrical system and an electrical problem; rightfully so!
DocCola
15
Aug 17, 2008 09:33 AM
RunEvo
May 11, 2007 07:05 PM
