Loosin BOOST with Hallman
Old Apr 11, 2004 | 03:54 PM
SuperchargedGTZ's Avatar
at first when I installed my hallman i had thought that the boost was rock solid to 20. but just recently i noticed that boost is fallin to like 17. It is not fallin fast like before without it, but around 7300rpm it starts to fall to 17. I had read a previous post about using the heavy spring, so installed the spring and I am still getting some tapperage (haha..is that a word) anyways, i have tighten all my connections and it everything checks out. ANY ideas?
Old Apr 11, 2004 | 04:51 PM
propellerhead's Avatar
My guess: Boost leak. Pressurize your intake tract and if you've got a leak you'll find it pretty quickly.
Old Apr 11, 2004 | 04:57 PM
MYEVOVIII's Avatar
Everyone I know that has the Hallman MBC still has some taper about 1.5 to 2 psi drop in higher rpms.
Old Apr 11, 2004 | 11:32 PM
GREDDY's Avatar
Tighten your BOV hosses and I/C hosses. Hopefully this helps. I am running 1.4-1.5bar to redline consistantly. It doesnt drop unless you let off the gas(well according to my boost gauge anyways).
Old Apr 11, 2004 | 11:36 PM
Ultor's Avatar
Mine does the same thing. Doesn't start to drop untill after 5K rpm. Falls to 17 just like yours. I'm pretty sure I read a few other post around here, of others with the same prob.
I took it apart and put it back together again, making sure everything was tight... no change.
I might try a 1g bov, or the Tomei one.
Old Apr 11, 2004 | 11:49 PM
GREDDY's Avatar
I am running Turboxs HPmbc by the way. I personally think it's a better MBC. When I first set it up it was holding 1.4-1.5 bar(whichever I set it to) and would drop to 17 by redline then I started messing around with the fine tuning side and now holds 1.4 or 1.5bar to redline. It's a little more expensive then the Hallman but its worth it.
Old Apr 12, 2004 | 07:12 AM
thanks for help everyone.
I will try and see if there is a leak.
Old Apr 12, 2004 | 07:25 AM
prowler's Avatar
Yea, there has to be a leak somewhere!. I could boost in excess of 1.5 bar all day long if I wanted to.
I love turbo cars, but unfortunately, almost all of them at one point suffer from boost leaks. It can be quite a challenge sometimes to track them down, especially if pressurizing the intake yields no leaks.
