Evo 7 Motor rebuild
Evo 7 Motor rebuild
I have an evo 7 motor that needs a rebuild. Spun a bearing and knocked pretty bad. I also have an evo 4 motor laying around with a good crank. Would I be able to use that crank on the evo 7 motor or is it weaker ?
It depends on how bad the damage is. In some cases the journal on the crank can be ground and repolished. You would just use an oversized bearing to support it.
I would do this if I was back stateside. The price for machine work in Japan is ridiculous!! I have a evo 4 crank thats perfect and ready to go so I was curious if it was the same.
