FP hta 71 CHRA
Old Apr 10, 2019 | 06:24 AM
Nikoro's Avatar
FP hta 71 CHRA
Hello guys. I m interested in forced performance FP CHRA hta 71 and was wondering if this turbo is compatible with the evo 9 stock turbo and what modifies needed for this installation! Thanks a lot!
Old Apr 10, 2019 | 06:44 AM
Yeah, a lot of us run this, including myself.
  • Yes, its compatible for the 8 or 9 turbo. If you install it on an 8 you will need the FP install kit
  • a 84MM intake pipe needed
  • Tune needed
  • Supporting mods (fuel pump/injectors etc)
  • No modifications needed to mount. Its a straight cold side upgrade. No fabrication or other mounting mods needed
Old Apr 10, 2019 | 07:26 AM
Nikoro's Avatar
How much power this turbo can give? With gsc s2 cams? (including full exhaust, 340 fuel pump, 1050x id, ets 3.5 inch i /c and hks intake)
Old Apr 10, 2019 | 07:58 AM
With my tune, on E85 (Running S2's & 1000cc RC inj) i made 460 DynoJet HP. So in my case, the HTA71 & the S2's netted approx 45 Dynojet WHP
Old Apr 10, 2019 | 08:01 AM
Nikoro's Avatar
With my tune, on E85 (Running S2's 1000cc RC inj) i made 460 DynoJet HP. So in my case, the HTA71 & the S2's netted approx 45 Dynojet WHP
stock internals ?!!
Old Apr 10, 2019 | 08:40 AM
Yes, stock bottom end & head except for S2's (@25 PSI)
Old Apr 10, 2019 | 04:11 PM
@Nikoro
One important fact i left out:
My results were somewhat muted as the tuner ran out of injector, otherwise there may have been another 20+ WHP at higher RPM
