Transfer Case Outer Shaft Scratch?
Old Apr 25, 2019 | 10:31 AM
steven121's Avatar
Tried lowering the engine in the car about a couple weeks ago and decided to wait for the head to be ported.
saw this just now and wondering if it will be fine before I install the motor
Old Apr 25, 2019 | 10:52 AM
kikiturbo's Avatar
yeah, just fine...
Old Apr 25, 2019 | 10:56 AM
Pal215's Avatar
Scratches like that are fairly common. If it is recessed you don't have to do anything and you will be fine. If it is raised, I would carefully file it down smooth with either a dremel sanding bit or a file so that it is flush with the rest of the shaft. I don't believe that surface would score a seal and cause it to leak.
Old Apr 25, 2019 | 07:31 PM
barneyb's Avatar
The o-ring behind it is chowdered.
