i need help
Old May 20, 2019 | 07:09 PM
kamal kamal's Avatar
i need help
1 : can i use 2.4 4g69 pistons and crank on my evo block 4g63 . can these pistons withstand pressure and heat?
2 : what kind of pistons can replace 4g63 pistons and work without problems ?
Old May 21, 2019 | 12:52 PM
joey pierce's Avatar
4g64?
U mean 4g64 pistons in ur 4g63? 4g64 is 2.4l 4g63 2.0
Stock 4g64 pistons n rods rnt worth anything. These motors are naturally aspirated. The pistons and rods are no good.
Old May 21, 2019 | 01:56 PM
This sounds right
Old May 21, 2019 | 02:00 PM
kikiturbo's Avatar
he is talking about 4g69 which is a 2.4 that has the same deck height as 4g63...
Problem is, that is 87 mm bore which is a bit risky on evo block.. Also CR is a bit much for turbo engine on pump... I think it makes no sense..
