Why do people replace ACD with viscous coupling?
Old May 31, 2019 | 11:19 AM
kikiturbo's Avatar
According to the evo 9 wiring diagrams the AWD Controller takes direct input (spliced into the same outputs) from the TPS sensor, Steering angular velocity sensor, G-Sensor (Longitudinal), G-Sensor (Lateral), parking brake switch, and the stoplight switch. All the wheel speed sensors are wired directly into the ABS Controller. There are then what appear to me to be 5 data wires connecting the ABS Controller to the AWD Controller. There is one wire going from the AWD Controller to the ECU.
I'll post the diagrams if anyone is interested.
yes but you can wire the wheel speed sensors into the 4wd ecu and run it without ABS if nedeed
Old May 31, 2019 | 11:32 AM
Biggiesacks's Avatar
So maybe that's 4 of the 5 wires going from the ABS into the AWD
Old May 31, 2019 | 11:47 AM
I found the diagram for ACD w/out ABS, the speed sensors are wired directly into the AWD controller, and they match 4 of the wires that are connected to the ABS. C-139 Pins 6,7,8,9. So its almost certain that the ABS controller is just passing along the sensor signal to the AWD controller. No clue on that fifth wire though C-138 pin 48, seems absent from the Non-ABS diagrams.
Old May 31, 2019 | 02:48 PM
Dallas J's Avatar
Veteran: Army
Originally Posted by lost spyder
I cant speak too much for the acd alone but i know autocrossing my X i was overwhelming the acd/ayc system. The diffs would screech and howl on aggressive corner exits or just unload all together after a few seconds and make the car push hard. Its nice to have but i feel that it loses a bit of its effect once big tq, corners, stiff spring rates and big hoosiers come into effect.
As Sean said, this is definitely not something common. I've beat on the ACD quite a bit, perhaps longer/harder than a significant majority and have looked at my plates a couple years ago with no signs of odd wear. I'll pull them again end of this year and recheck, but no funny noises or weirdness in mine or anyone else I know in the AX crowd.
