Really Strange...
Old May 29, 2019 | 01:51 PM
7rrivera7's Avatar
Really Strange...
I am a shade tree mechanic and have self-maintained several "performance" cars but my EVO 9 is the first with forced induction and I've never experienced what I am about to explain...
If I drive the car on the highway and keep the revs stable on level ground, I can feel a slight acceleration followed by a slight deceleration and then it repeats endlessly. I have no idea where to start troubleshooting this but feel it has to do with the combustion event deep inside the engine.
If anyone has experiences this, please comment on how you resolved the issue. Thanks!
Old May 29, 2019 | 01:56 PM
kaj's Avatar
kaj
Are you in vacuum when it does this?
Old May 29, 2019 | 02:09 PM
7rrivera7's Avatar
Yes - no boost as if I was driving a naturally aspirated car.
Old May 29, 2019 | 02:16 PM
LetsGetThisDone's Avatar
Probably the BOV opening and closing. What BOV is on it?
Old May 30, 2019 | 10:49 AM
7rrivera7's Avatar
Tial 50mm
Old May 30, 2019 | 11:09 AM
Originally Posted by 7rrivera7
Tial 50mm
Yeah, you're probably coughing the BOV. Put a lighter spring in it, the -5psi or -6psi spring.
Old May 30, 2019 | 02:58 PM
7rrivera7's Avatar
What does that mean?
Old May 30, 2019 | 03:07 PM
kikiturbo's Avatar
yeah, sounds like the blow off valve being closed.... what happens is that you cruise with small throttle but your turbo tries to build boost. Since the throttle is at a small opening, the air builds up in front of the throttle and goes back trough the turbo intake... In fact it is a wave... This then hits the MAF annd messes up its reading... as a result you get a hiccup in power..
Old May 30, 2019 | 03:45 PM
This same scenario causes the BOV to rapidly open and close, causing the shutter/stutter.
Old May 30, 2019 | 03:51 PM
kikiturbo's Avatar
sure, can be... I had the similar issue when we installed the hks turbo and some cams... it would surge like mad even on stock bov and was undrivable during cruising.. Converting to SD solved it even though I can still hear the surge. Yeah, the OP should experiment with BOV spring and preload..
Old May 30, 2019 | 05:29 PM
7rrivera7's Avatar
That's also happening!
Old May 30, 2019 | 05:30 PM
7rrivera7's Avatar
Thanks for your insight. I will work with a lighter spring to see if it helps
Old May 31, 2019 | 08:45 PM
leemaster's Avatar
Veteran: Army
^ This, try that out first and see if it fixes it. GL
