Clutch slipping or not ?
Old Jul 23, 2019 | 02:42 PM
PalmTreeZ's Avatar
Hey guys ive been having some trouble recently after i launched my car with some of my friend in it to show them what a launch was. Ive done it countless of times having owned the car for so long and never had this problem before. I get the car rolling and let go of the clutch quickly without dumpint. Smelt some burt clutch right after but went away very quickly.(tldr: Now on the freeway im having my clutch slip in forth and fifth gear when underload but 1st second and third dont slip.... so what the **** is my real question.... shouldnt a clutch be slipping where theres more tuorque from gears not the higher ones...)
Old Jul 23, 2019 | 03:47 PM
carbon_toast's Avatar
5 Year Member
You'll see the clutch start to slip in the higher gears first. Reason is there is less of a mechanical advantage in the higher gears, they take more work to turn than lower ones (including extra work overcoming the air since you're traveling faster). Your clutch will wear out eventually, especially if you have launched it countless times. Sounds like its time for a new one to me.
Old Jul 23, 2019 | 05:08 PM
hutch959's Avatar
you need a new clutch.
Old Jul 23, 2019 | 05:54 PM
PalmTreeZ's Avatar
Do you guys know of any clutches perfect for around 350-400 whp? That could take up to 450ish im planning on an fp green, 272 rods and e85 installs in the future to hit that power. I know id want a lightened fly wheel but what are some companies to look out for and ones to go for ?
Thank you guys for always helpin
Old Jul 23, 2019 | 06:00 PM
The advice noted up above is pretty sound for sure. My stock clutch did the same while driving on the freeway
Anyway, sounds like you need the ACT HDSS. Many of us run that. Ive been in the 400+ WHP for years w/the ACT
Now, if your headed toward higher Dyno Jet WHP, the Exedy multiplate types may be in order
Old Jul 23, 2019 | 06:04 PM
PalmTreeZ's Avatar
Ahh thank you guys, also final question before imma off to look into clutches. What if i get that clutch for my future build of 350 ish whp but my car is stock ish rn will my cars power be able to use that clutch?
Old Jul 23, 2019 | 06:06 PM
The ACT HDSS will work for a stock application. Its like the OEM clutch but a bit more robust for sure! It certainly drives like a stocker. Super smooth!
Old Jul 23, 2019 | 06:07 PM
PalmTreeZ's Avatar
Ive heard some stories with 4 puck clutches and 6 puck just looked and saw some. They said these catch strong would that be a good choice for me if i track my car and take it to the canyons ?
Old Jul 23, 2019 | 06:10 PM
Nah, Sounds like the ACT is what ya need. The puck type, especially an unsprung type are very tough to drive & are hard on the drivetrain
Ive been using the same ACT HDSS since i was tuned on E85 (10 years ago). Power levels from 400 to 460 Dynojet WHP. Many miles on the same ACT
Old Jul 23, 2019 | 06:12 PM
PalmTreeZ's Avatar
Ahh thanks guys for all youre help, cheers
Old Jul 24, 2019 | 04:20 AM
NP's Avatar
NP
5 Year Member
Might want to check into the ACT clutch July special price they have going on. 30% off i believe.
https://www.advancedclutch.com/produ...ung-me2-hdss-2
https://www.maperformance.com/produc...o-8-9-me2-hdss
