Is there anyway to tell if a motor is a stroker?
Old Oct 7, 2019 | 08:34 AM
JR Sunhel's Avatar
Title. My friend is looking at an Evo to join me and the owner is claiming a 2.3L stroker built engine. Is there any way to see that?
Old Oct 7, 2019 | 08:58 AM
Dont think there is any good way to quickly confirm that! If the owner did the work he should have the build receipts
Old Oct 7, 2019 | 10:03 AM
GTA.RS's Avatar
A coat hanger wire down a spark plug hole and rotate the engine will show you how much the piston travel is.
88mm std, then 97 and 100 are the stroker cranks
Old Oct 7, 2019 | 01:34 PM
ctfpevoVIII's Avatar
They will typically spool the turbo up quicker because it’s creating more torque earlier . So if you know what turbo that’s on it and see where it spools up at you can compare to similar setups. But liked mentioned above ask for documentation and receipts.
Old Oct 7, 2019 | 04:26 PM
RS200's Avatar
Do GTA.RS' method, it's better than guessing about the characteristics that a stroker should exhibit. There aren't any better ways that don't involve disassembly, either.
Old Oct 16, 2019 | 08:55 AM
2006EvoIXer's Avatar
I think this is easiest way too. For evo 8/9, it's either 88mm, 94mm, or 100mm (2.3L). Make sure to use straight portion of hanger. Lol
ChicagoEvo9
Feb 7, 2014 06:48 PM
stck_trbo_mnstr
17
Apr 10, 2011 05:26 PM
jmelocik
Dec 5, 2008 09:28 AM
