Fp hta71
Old Oct 9, 2019 | 04:23 AM
Nikoro's Avatar
Fp hta71
Hello guys. The Forced Performance hta71 supercore that fp sells is a direct replacement with the stock mhi housing from an evo ix? You have to fit the existing stock mhi housing with this supercore or you need any other mods? Thanks a lot for your time reading this
Old Oct 9, 2019 | 05:12 AM
kikiturbo's Avatar
yeah, direct replacement... Depending on the compressor housing type you will need new inlet pipe.. .(I am not sure you can buy hta71 in stock inlet size at all)...
Old Oct 9, 2019 | 10:13 AM
LetsGetThisDone's Avatar
It's a direct replacement for an Evo9 turbo. If you have an Evo8 turbo, you will at minimum need the install kit that FP sells with the water lines, and turbo outlet. It's also not a bad head to replace the oil feed with the FP one that has the inline filter.
Old Oct 17, 2019 | 08:50 AM
xxthayxx's Avatar
you could go with the MHI TF06-18K turbo that FP sells which still use the stock inlet. Direct bolt-on i believe.
http://www.forcedperformance.net/mhi...or-evo-ix.html
Old Oct 17, 2019 | 04:58 PM
Bhsj13's Avatar
That one must have just come out. it wasnt there a few days ago. but for that price, i would just go ahead with a red.
EDIT:
nevermind, i forgot you have to choose the MHI version wich adds a bit to it. anyway, great price for a upgraded evo 9 turbo.
Rob_STI_PNW
Mar 9, 2018 10:49 AM
ihockey1
393
Jun 30, 2015 09:53 PM
Airflow86
Oct 25, 2014 11:23 PM
discopotato03
Jun 21, 2010 04:18 PM
twista
May 18, 2010 07:53 AM
