Not enough fuel
Old May 9, 2020 | 01:59 PM
kevinevo4's Avatar
Not enough fuel
Hi
I have an evo 4 with around 500hp that runs great on idle and low rpms. But as soon as i get on throttle and the boost comes on(3500-4000rpm), it starts to fuel cut. I have cleaned the fuel filter and the fuel pressure is around 4 bar at idle. My guess is that the fuel pressure drops as soon as i hit boost but i don’t know why. Could it be the fuel pump? Or do you have any other ideas?
Old May 9, 2020 | 04:58 PM
hutch959's Avatar
is your fuel system upgraded?
Old May 9, 2020 | 10:56 PM
MR ArcticC's Avatar
Hej på dig,
Is the vacuum/pressure hose connected to the fuel pressure regulator?
Old May 10, 2020 | 08:50 AM
SnailSpeed's Avatar
Is there a possibility that you may be confusing fuel cut with spark blowout? Pretty common on these cars if you have a weak ignition system and a large spark plug gap.
Old May 14, 2020 | 02:24 AM
kevinevo4's Avatar
I have already checked the sparkplug gap, which is good. The fuel pumps are upgraded and both work. And the vacuum hose is connected to the fuel pressure regulator. I’m thinking that it might be a clogged fuel filter, and the fuel lines are not really connected like they should so i will check that.
Old May 29, 2020 | 07:33 PM
Shamsiel's Avatar
Veteran: Army
Did you get an upgraded fuel siphon or drill out the stock one? If its not then fuel pressure will be high as **** in the tank and over run the regulator and injectors in boost. Also if you have a walbro 450 make sure its the high pressure 274 model, the 267 model bypasses at like 80psi.
Old May 30, 2020 | 12:53 AM
LetsGetThisDone's Avatar
That's not how that works.
Old May 30, 2020 | 03:57 PM
Shamsiel's Avatar
Veteran: Army
Tell me more about how I fixed the issue on my own car......
The in tank pressure was too high causing the injectors to fire incorrectly, causing regulator pressure to be 70-80 psi at idle, and causing the in tank pump to bypass when in boost. All because the stock siphon diameter, on the stock hanger was too small to flow the amount of fuel the pump was trying to supply.
Mauricio Evo IV
Apr 8, 2019 12:31 PM
sieberhagen
15
Mar 12, 2018 06:55 AM
Faisalm
Mar 23, 2015 02:11 AM
umiami80
Turbotrix Racing - Edison, NJ
Apr 21, 2005 12:55 PM
