S90 throttle body question
Old May 29, 2020 | 10:58 AM
Willpegley's Avatar
Do I need to use whatever sensor went here? It’s a 74mm tb and it’s going on my 8. I think it’s meant to have a different sensor to what the 8 uses but what I’m building is in no way a stock evo it’s fully built so just wondering if this is needed or can be blanked off somehow?
Old May 29, 2020 | 11:08 AM
LetsGetThisDone's Avatar
There is an adaptor to put the OEM ISC motor there, you should buy it and install it so you maintain idle control with the ECU.
It's pictured here, you may need to call S90 directly to get it if you don't have it-
https://stmtuned.com/collections/mit...hrottle-bodies
Howulikemyevo
Dec 17, 2013 10:38 AM
lancerralli06
Mar 5, 2011 08:17 PM
L888Apex
Apr 10, 2010 06:58 PM
crippin_evo
Oct 13, 2003 01:51 PM
