EVO VIII vibrating noise
Old Apr 14, 2004 | 03:19 PM
yellevo's Avatar
Cool EVO VIII vibrating noise
I need to know if anyone knows what a noise is ; which comes from under the hood ; which by the way only happens when it rains , it sound like a motor mount is loose or something . vibrating of metal does any one know what this problem would be . It doesn't happen long enough to get out of the car and find it . (Imagine your car with an exhaust on it and the pipe is vibrating against the bottom of the car ) ok ten times worst can it be the transmission or is it something else ? If some one knows what the problem is hit me up yellevo on the evo forum or at DSMBB1@aol.com
Old Apr 22, 2004 | 11:37 AM
Hanzo's Avatar
Mine has weird noise when my AC is on, seems like since the AC puts extra load on the engine it actually made enough vibration to create the noise. Not sure what is vibrating.
Old Apr 22, 2004 | 11:54 AM
EV0lut10n_8's Avatar
does it happen only at a certain rpm?
Old Apr 22, 2004 | 12:17 PM
1QWKEVO's Avatar
i have a vibrating noise but only when u initially let the clutch out.. its a very minor slight sound but its hella annoying
Old Apr 22, 2004 | 12:25 PM
budlong's Avatar
sounds like mine...
https://www.evolutionm.net/forums/sh...567#post796567
i would say its normal.. cuz they "fixed" it, and its even louder now
Old Apr 23, 2004 | 08:22 AM
vegeta irie's Avatar
I have the same problem. Oddly enough it started happening after i got my HKS DP and UR test pipe installed. It seems to happen when I let out the clutch and rev to about 1800 RPM. What I gather from your post Budlong is that this is normal and I shouldn't worry about?
Thanks,
Josh
Old Apr 23, 2004 | 08:32 AM
Hungbee112's Avatar
My heatshield on the hood was loose once that caused some vibrating noises. See if that's it.
Old Apr 23, 2004 | 10:54 PM
SzuChenEvo's Avatar
I have the same exact problem. The sound especially comes on when I turn on the AC. Has anyone solve this problem?
Old Apr 26, 2004 | 03:36 PM
Gumpy's Avatar
YellowEvo,
Do you have an aftermarket 3 inch exhaust? If you do, that is likely the culprit. The tolerances are tight for a 3 inch exhaust and when it rains, the rubber hangers get wet and the exhaust moves slightly back and forth on the hangers and hits in spots where the tolerances are tight (rear diff, bearing carrier for driveshaft, oil pan, tranny, etc). Took me a while to figure this out. Hope it helps.
Gumpy
