Transfer Case Whine
Old Oct 3, 2020 | 05:08 AM
USMC Brad's Avatar
Veteran: Marine Corp
Transfer Case Whine
I'm pretty sure my transfer case is starting to whine on my 05 MR. It's very quiet in the lower gears but in 5th and 6th with the windows up I can hear it clearly. How long should I be able to drive it like this? Does it affect performance? It's not too loud at all but I can definitely hear it.
Old Oct 3, 2020 | 11:33 AM
MR ArcticC's Avatar
Are you sure it's the transfer case? I have 05 MR too and the whine appears around 60 mph and it's the rear diff making the whine. I would take the car on a lift and let a mechanic listen to the parts while you drive the car.
Old Oct 3, 2020 | 12:16 PM
USMC Brad's Avatar
Well I found out I had a very minor leak on one of the seals on the t case. The seal had very little fluid on it. So I'm guessing it's the t case. The fluid was changed within the last 2 months.
Old Oct 3, 2020 | 05:25 PM
hutch959's Avatar
did you check the fluid level on the transfer case?
Old Oct 3, 2020 | 11:35 PM
Jonno99's Avatar
Pump it from below until it comes out the top, then drive it, then pump it again
Samanttha
Feb 17, 2016 06:18 AM
marinejensen
Feb 23, 2014 10:21 AM
o_SHOX_o
Australian Forum
Nov 15, 2011 09:15 PM
GottaGoFaster
Dec 3, 2004 08:23 PM
