Running on 3 cylinders at wot.
Old May 21, 2021 | 08:11 AM
Spongebob's Avatar
My evo 8 is running on 3 cylinders at WOT, but at idle and normal driving its fine.
It started after i changed to uppgraded lifters but then it was missfiring just allitle just like a half second and then it was fine and this have been coming and going but now its worse after 2 months (yes i should have done something about it earlyer but im very busy at work and so on). Now it runs on 3 cylinder at WOT and i was suspecting vaccum leak or coils or the sparkplug wires to be bad.. But the vaccum is around 50 CM/HG so i guess there is no vaccum and i have changed the coils cuple of times because they went bad.. Any ideas on how to solve this ?
Old May 21, 2021 | 09:16 AM
Biggiesacks's Avatar
I'de start by inspecting the spark plugs, and do a boost leak test. You might want to verify cam timing alignment just in case. When ever I have an issue after a job I try and carefully retrace my steps, and often I will find the culprit doing that. Why did you replace the lash adjusters? What's the status of your timing belt?
Old May 21, 2021 | 03:58 PM
Spongebob's Avatar
Il check the sparkplugs tomorrow and check if i can get the tools to doo a leak test.
I did retrace my steps, but i cant seem to find anything.. maybe the seal around the screws to the valve cover or the main gasket around the valve cover is leaking?
I changed the lifters to upgrade them to 3mm lifters.
the timingbelt is brand new and the timing is spot on if you ask me.
Old May 21, 2021 | 04:31 PM
wht95scort's Avatar
Check for codes. Which cyl is missing during WOT? Possible valve float. A compression test and leak down test can also help figure out what’s going on but start with the basics and check for codes.
Old May 22, 2021 | 04:55 AM
Spongebob's Avatar
I dont get any fault codes and the car only runs at 3 under load, if i rev it in neutral its fine.
Old May 22, 2021 | 07:04 PM
Grevolution's Avatar
What exactly are the symptoms that make you believe that it is running at 3 cylinders under load? Usually a misfire under load on a specific cylinder is usually spark related.
wrinkly
Sep 5, 2017 05:40 PM
R. Burgundy
Jun 5, 2014 11:58 AM
xRoguex
33
Feb 11, 2011 02:15 AM
sXericerider
Lancer Troubleshooting
Nov 14, 2009 02:12 PM
0db
Apr 21, 2005 10:40 PM
