2.3 or 2.2 build with stock ECU/OEM tune
Does anyone know if you can run a stroker engine (2.3 or 2.2) with the stock ECU on OEM tune without throwing any codes. Im looking to build my engine, but if i cant pass smog in CA where they now know if your ECU has been flashed then i might just do a 2.0 build.
I would expect it to run poorly, if it's not outright dangerous. You're adding 15% more air flow with a stroker with every RPM - you need 15% more fuel, which the ECU will try to compensate with LTFT, and I presume you'd run out of room there, where a code would be thrown. At WOT, where it's based on a pre-set fuel map and not based on oxygen sensor feedback, you'd likely blow the motor from going too lean.
[WTB] Evo 8 ECU - stock tune
Migsubishi
May 18, 2016 12:37 PM
Biggiesacks
Mar 9, 2016 02:08 PM
TURBO_S2K
Jan 18, 2013 06:51 PM
