Another 4g64 timing questions.
Old Oct 3, 2021 | 08:29 AM
blackline's Avatar
5 Year Member
Trying to time my 4g64 block and 4g63 head. Using a evo 9 timing belt
this is what I did,
  1. set cams to zero on inner and outer ring
  2. set crank to notch
  3. set oil gear to dot(BS delete)
  4. put the timing belt on
  5. tensioned it
  6. cams are now off by 2 degreas
  7. i moved the inner cam back to the valve cover Timing marks
not sure If this is the correct way to do it. Does everything look good?
Old Oct 4, 2021 | 12:30 PM
Dallas J's Avatar
Veteran: Army
Yep, looks correct. It doesn’t matter what the outer mark points too, what matters is the what the “zero” lines up with. And both yours are pointing at the timing mark. The only thing that sticks out is how far you moved them. You’re at 2deg of correction and should be about 3.5 deg for a 2.4. Though that can all depend on factors like head decking, HG thickness, oil pump gear…
lining up with the valve cover definitely gets you in the ball park though.
Old Oct 4, 2021 | 04:13 PM
blackline's Avatar
5 Year Member
Thansk man, I was banging my head against the wall trying to get it to the 3degress mark but can't. Head was deck(.003) and block was "dusted" twice.
Old Oct 4, 2021 | 04:32 PM
hutch959's Avatar
mine were at about 3.5
babaz7
Aug 6, 2014 07:23 AM
SS1000RR
Feb 22, 2014 01:44 PM
4mypsp
Nov 9, 2010 11:51 AM
idriveanevo
Apr 4, 2007 03:40 PM
coltmac45
Feb 9, 2004 08:56 PM
