Need Help With this error code P0108
Old Sep 7, 2022 | 08:38 PM
zack_evo's Avatar
Question Need Help With this error code P0108
Hi all,
After doing an ecu check and now seeing this fault code P0108: MAP/Barometric Pressure Sensor Too High. Not sure what is sensor too high. Normal error is either related to voltage or circuit high input. The problem still exists despite the replacement of the MAP and MAF sensors. Now, I'm unsure of what to do. Need help
p/s: current barometric reading is 99kpa
Thanks
Old Sep 9, 2022 | 05:27 PM
CDrinkH2O's Avatar
As you already replaced the MAF with a known good one, the most likely cause for this code to be set is an open barometric pressure sensor circuit. This could be anything from connector damage on pin 2 of the MAF connector, broken or damaged wiring between it and the ECU, or damage to ECU pin 85 (Evo 8) or pin 51 (Evo 9).
Old Sep 11, 2022 | 11:47 PM
zack_evo's Avatar
Hello,
I really appreciate your information. I will inspect the MAF and ECU wiring and pins. Will test the voltage continuity, and report back my findings.
Many thanks
dahuii77
Oct 7, 2011 12:21 PM
dahuii77
Aug 8, 2008 01:05 PM
dahuii77
Aug 7, 2008 11:06 PM
SidewaysEvo
Jun 13, 2007 09:49 AM
phish52
Nov 12, 2004 06:48 AM
