Serious Electrical problem!! HELP!
Old Apr 17, 2004 | 03:22 PM
JoseEvo's Avatar
see the problem is all of the fuses are little pictures... does anyone have a diagram for our cars?? i've seen one for the ecu and i think i've seen a diagram for the entire electrical system.. if someone could provide thatd be great.. i also checked this fuses:
Old Apr 17, 2004 | 03:33 PM
JoseEvo's Avatar
how do I check relays? with a multimeter?
Old Apr 17, 2004 | 03:43 PM
JoseEvo's Avatar
by george i think i got it! there's a little picture of a key and i pulled it out and found a little green box with some stuff in it. on the top of it it says 40 and if you pry it off i saw that the top of it is broken. i think that's it...
Old Apr 17, 2004 | 04:58 PM
JoseEvo's Avatar
check these out... i think this is the problem. i'm assuming i can pick up a replacement at any auto parts store?
Old Apr 17, 2004 | 08:53 PM
JoseEvo's Avatar
hey guys, where can i buy one of these.. this is the culprit.
Old Apr 17, 2004 | 09:42 PM
silverEVO8's Avatar
If I remember correctly, that yellow square, funnel like thing covers or hides a few more fuses that you want to check.... that's where the one I blew resides.....
In the picture where you see the red and ble fuses on top of the yellow label, the legs of the blue fuse point to the yellow thingie that I'm talking about
Old Apr 17, 2004 | 09:59 PM
nebolic's Avatar
stupid questinos but you checked both fuse boxes right, the one inside the car and the one underneath the hood.
Old Apr 17, 2004 | 11:05 PM
Deceit's Avatar
I'm pretty sure you can pick one up from the dealer.
Old Apr 18, 2004 | 01:11 AM
bpclements's Avatar
Those two fuses in the yellow deal are for the dome lights, radio, and clock.
Old Apr 18, 2004 | 01:21 AM
4G63_Attack's Avatar
if not the fuses try looking at the turbo timer. that might be died. just my .02 cents on this
Old Apr 18, 2004 | 02:27 AM
simevo's Avatar
Check all the wires you spliced and make sure non of them got disconnected or burnt out. Also, check the positive terminal under the red cap on the battery. There is a built in fuse on the terminal.
Old Apr 18, 2004 | 08:22 AM
JoseEvo's Avatar
guys I figured out the problem... it's the green 40 amp thing.. where can i get a replacement?>
Old Apr 18, 2004 | 08:29 AM
simevo's Avatar
Good to hear! Just to show when there is any electrical problems, check all the fuses.
Old Apr 18, 2004 | 09:26 AM
JoseEvo's Avatar
yup... i didn't know that was a fuse.. could i get this part from any auto parts store? looks like a fuse but its shaped differently.
Old Apr 18, 2004 | 10:24 AM
silverEVO8's Avatar
It's unlikely that it's a special part. However, you might have to go to the dealer for it. Maybe if you take to the parts store they can find it's replacement.....
Good luck
