Serious Electrical problem!! HELP!
Old Apr 17, 2004 | 01:18 PM
JoseEvo's Avatar
FIXED read last post!!
Old Apr 17, 2004 | 01:19 PM
sr20det91's Avatar
Start checking fuses and fusable links. Its likely your problem.
Old Apr 17, 2004 | 01:30 PM
JoseEvo's Avatar
just checked all my fuses, none blown.
could I have blown the starter? it doesn't seem to want to get into any other mode (acc, on, start etc) and only the headlights, warning siren, and the map lights work.
the starter is the thing the harness is connected to right?
Old Apr 17, 2004 | 01:37 PM
simevo's Avatar
Check the fuses in the engine bay. Look very closely at the fuses and take some out since some times you can't tell the condition of the fuses unless you take them out.
Old Apr 17, 2004 | 01:39 PM
JoseEvo's Avatar
i pulled every fuse i could find, and none were blown . im beginning to think it's the starter thing that the harness attaches to because i cut the wire from the harness and that was the one that blew...
i thought fuses protected against this sort of thing my stupidity..
Old Apr 17, 2004 | 01:45 PM
Dale_K's Avatar
Try resetting the ECU by disconnecting the battery for about 10 minutes. I doubt that is really the problem but it's worth a shot. I don't think cutting a wire can screw up a starter.
Old Apr 17, 2004 | 01:52 PM
JoseEvo's Avatar
i just double checked all my fuses... none blown .... i've been letting the battery sit without the negative for a while and tried to start it but still nothing... i cut one of the extra wires off my greddy harness and hit the steering metal column and it sparked... i even took my greddy turbotimer off and harness and put the stock harness in and it didn't work!!!
Old Apr 17, 2004 | 02:08 PM
TRDHarrier's Avatar
i had a similar problem. I needed the lights in my car and totally forgot about the electrical shorting thing even though I'm an engineer. Dumb me. But I found that there's a fuse that attaches itself to a yellow plastic thing which contains two fuses inside. Pry it out. It was a ***** to take out. I had to take it to Mitsubishi to take it out cuz I spent an hour trying but no luck. My car started though. A short shouldnt damage much.
Old Apr 17, 2004 | 02:16 PM
JoseEvo's Avatar
TRD, those were the first I pulled with needle nose plyers, they were OK.
I put the key in, and all it does is beep.
Old Apr 17, 2004 | 02:25 PM
JoseEvo's Avatar
please help guys... i can't afford to bring it to the dealer and to have it towed... . the starter on the steering column is the only thing i can think of
Old Apr 17, 2004 | 02:38 PM
morefaster's Avatar
Check every fuse again with a testlight and if it doesn't light check it with a multimeter, sometimes they look good even blown.
the line that is blown it the one that corresponds to the wire you shorted, it sucks, but follow the voltage on that line.
the fact that your lights work and the buzzer works probably means you didn't fry too much.. good luck
--i'd bet your starter is fine
Old Apr 17, 2004 | 02:52 PM
JoseEvo's Avatar
the wire that I cut was one of the extra wires off the greddy harness bridged off the red one... i was going to just electrical tape it up because it just kept getting in the way... looks like it's the main power one ... i keep checking fuses but no luck i will upload pics in a sec
Old Apr 17, 2004 | 03:12 PM
JoseEvo's Avatar
ok guys here is some pics.. they are not of best quality but here you go...
i tried switching a bunch of fuses around in the engine bay with no luck.. i will try switching under the dash. does anyone have any fuse diagram as to what this wire is linked to?
silverEVO8's Avatar
There are more fuses under the plastic cover in the fuse panel in the engine bay. I had a shorg that blew a fuse in there, not a serious as your problem, but it was a b!tch to find and replace. Those Plastic covers and the fuses under them are not easy to get to or to replace. It's actually quite difficult to do without breaking something. They don'tb really want you messing in there I guess..... Keep trying, it's only a blown fuse. You'll get it fixed.
Old Apr 17, 2004 | 03:13 PM
jaymz916's Avatar
As a former car audio installer, and now a slot technician, I will tell you that just because you pull a fuse and look at it, and it looks good, doesn't mean it is good. Check the fuses with a dmm. I'm 99% sure it's a fuse or a relay under the hood. It's probably be the fuse labeled stater, or ignition.
