XClutch Twin Disk Sprung Organic Clutch: Unboxing, First Impressions, and Review
Old Feb 11, 2026 | 08:00 PM
  #46
Dallas J's Avatar
Veteran: Army
Originally Posted by Jhero23
Can you guys provide information on the installation?
Did you use the ACT monoloc?
Did you use an OEM throwout bearing? Or did you use the supplied throwout bearing?
Did you follow Jack's clutch adjustment? Or did you just do the oem freeplay method?
Any clutch burnt smell after launching?
  • I pulled monoloc from an old clutch and swapped it on. No reason not to run one at this point, they're just better.
  • Always OEM TOB. Even if the aftermarket one looks good or equivalent the bearings are sub-par and will always fail early. Id reuse an older OEM than use a new Aftermarket.
  • Sort of, yes. I adjust to the limit of travel like Jacks method then work my way in depending on where I want my clutch to engage. The Jacks adjustment was a bit more of a necessity on 2g DSMs than Evos, but its good to know the travel limit.
  • Dont recall any smells, but I dont launch super hard typically.
Old Mar 26, 2026 | 03:09 PM
  #47
envyno1's Avatar
Veteran: Coast Guard
Any outside of car videos of the clutch chatter to see how loud it is when the pedal is depressed?
any advantages that you see over the ACT twin mod? I hear more horror stories on act over xclutch
Old Today | 12:31 PM
  #48
Jhero23's Avatar
Post# 26
https://www.evolutionm.net/forums/ev...t#post11974117
nglett
17
Oct 10, 2019 02:11 PM
evo8john
Feb 16, 2011 08:20 AM
CaymanEvo3
Nov 22, 2006 09:20 AM
scorke
37
Apr 6, 2006 02:29 PM
ev08buoy
17
Sep 3, 2005 03:17 PM
