Artec vs Hypertune manifold
Suppose you're right as I've heard the early boost/torque of the Evo 9 is actually not great for stock rods.
I'm just kinda torn between a full rebuild, a rod job, or just send it as is. Have to take the head off anyway for ARP studs and fresh Evo 9 headgasket, cams and springs.
Here in New Zealand, engineers don't seem to be keen on machining the pistons for aftermarket rods, instead they just keep telling me I need forged pistons and not listening to the concept of OEM pistons.
I installed the Artec manifold on my IX with stock turbo. Seems to work well spool is as good as stock or better. Only surprise is the stock heat shield can be reused but the bolts are M6 not the factory M8. They could be retapped but I did not want to do that since I had already installed the manifold before I noticed this. You may also have to modify the O2 housing to block bracket the position seem to be shifted slightly. Could also have been the non-Oem O2 housing being off.
Mitsuatb
Mitsuatb
This is the first time I heard someone trying to reuse the stock pistons with aftermarket rods. I dont understand what you are trying to achieve but from my POV its seems like a bad idea.
As an engineer in America I would suggest listening to the engineers in New Zealand.
I wanted to do it to avoid boring and using oversize pistons, as well as keeping factory piston to wall clearance. I don't like how forged pistons rattle on cold start and breathe more.
I Know this isn't always the case but it seems more common than not.
My goal isn't massive, but i feel it'll be on the limit of the stock bottom end
O for sure, but you know how people get when they are getting a tune.
Make it spool faster, 1 more psi, why does it make so little power lol
Just wanted to throw it out there so he could think about the actual goals for the car as opposed to keeping the stock turbo for ?? reason.
Rodjobs are pretty common in the Evo community, most seem to have great success retaining OEM pistons and upgrading the weak rods to something stronger, only machining required to the piston is circlip grooves for the wrist pins as the factory wrist pins are press fit into factory conrod small end.
Forged pistons don't rattle if your machinist doesn't suck, and you choose a quality piston (wiseco 1400hd, hint hint). I build about 20 4g's a year. Not a single one rattles the pistons on cold start. Even the high power ones at .005" PTW.
Full-Race.com
33
Apr 28, 2011 12:00 PM
USP45
Feb 27, 2005 08:38 PM
