80a enough for alt fuse?
Old Jul 24, 2024 | 08:17 PM
RallySport9's Avatar
So In my stupidity I have installed a new alternator and forgot to put the plastic spacer back on the power wire, this of course resulted in a short and popped the 120a fuse on my fusable link (battery relocation kit). I checked up and the evo 8/9 uses a 100a fuse for alternator however all I have left is an open 80a fuse spot. My question is could I run this lower amp without the fuse popping? I will be ordering a new fuse box link since they aren't that expensive I was just wondering if I can confidently drive the car without worrying about the fuse going and stalling for the time being, and possible damaging the alternator?
Old Jul 25, 2024 | 12:46 AM
ViciousLSD's Avatar
i think that should be fine unless youre jumpstarting with a dead battery. I believe the fuses for the alternator and starter is to protect the battery from an internal short or exactly what you did
Old Jul 25, 2024 | 05:57 AM
alright thanks, that makes sense. I guess the alt will put out what it needs to charge/power accessories and that will never reach over 80a you’re saying unless I jump the battery or short it out again.
I will take the car out then and report back for anyone in the same situation.
Old Jul 25, 2024 | 02:35 PM
Update- I’m suddenly noticing something weird. No door chime when the key is in the ignition like it used to. I then checked the engine bay fuse box and found a blown 20a. Replaced it. Chime still doesn’t work. Everything else seems to be functioning just fine. Is it possible the surge could have blown other fuses via the link?
edit- the chime magically works again? Kinda bummed I wouldn’t mind if it somehow failed lol went out for a drive alternator functions good, batt stays fully charged.
ekinshuya
Jan 13, 2015 05:49 AM
raytrix
Sep 21, 2009 09:41 PM
RA032924
Apr 1, 2009 12:13 AM
m4tt VIII
Dec 24, 2007 08:13 AM
jeffreyinigo
Nov 22, 2007 08:27 PM
