Wiseco piston installation problem
Old Mar 1, 2025 | 10:32 AM
roadracer47's Avatar
I am building a 4G 63 to stage three level and when attempting to install the pistons which are Wiseco 85 mm the piston skirt hits the piston oiler. I don’t know if they make an aftermarket piston oiler with a different offset or if I merely need to bend the oil nozzle slightly inward to clear the piston skirt. Any words of wisdom out there??
Old Mar 1, 2025 | 12:53 PM
Jaraxle's Avatar
I can tell you for the Evo X 4b11 and Cosworth pistons you have to bend the oilers a specific clearance to avoid collision. I can upload the pic/info from Cosworth on piston installation if you like even though it is a different engine and different piston. My point is that it IS common to need to make such a change when installing aftermarket pistons in these machines...
Old Mar 1, 2025 | 01:46 PM
RSMike's Avatar
Are you using 88mm or 100mm stroke crankshaft?
Tomei notch their skirts, that's an option for you too. BUT you will need to get them rebalanced.
Old Mar 2, 2025 | 03:52 PM
LetsGetThisDone's Avatar
Just delete the squirters. Plug the holes with a an M12x1.25 port plug. When you try to bend them they tend to just break.
Old Nov 25, 2025 | 10:08 AM
Oil squirters
I just recently rebuilt, my 4G 63 and simply carefully bent the squirters just enough to clear piston skirt using a flat blade screw driver. They are necessary for proper piston cooling.
Old Dec 2, 2025 | 08:02 PM
nightowl1985's Avatar
5 Year Member
Did you put the pistons in the right direction because if you have them wrong the clearancing for the squirters will not be where it needs to be.
Old Dec 3, 2025 | 06:51 AM
Definitely installed correctly.
Tyler Ransom
Apr 20, 2019 02:53 PM
stayer
10
May 23, 2017 09:38 PM
bignasty_yagn
Lancer Engine Tech
Apr 17, 2010 04:26 AM
konstantinosIX
33
Apr 23, 2009 06:05 PM
N1te
Dec 8, 2004 08:34 PM
